Quote Originally Posted by Mschumacher View Post
Thank you sir pajerokid for the reply. Yung HU na makukuha ko is not capable of full active pala e. it has 6 pre outs but two of each lang front, rear, and sub. What if I do it like this I'll get one 3 way active crossover to filter the frequency for my 3-way speaker. Then I'll set the crossover to front only then from there I'll filter the frequencies for tweeter, vocals and mid bass. then for the rear speakers I'll directly get the line from the headunit same goes for the subs. but the sub will definitely go through an amplifier. but for the rear it may or may not pass an ampli. if this would work would I still be needing the passive crossover that goes with the 3 way seps. thanks again for the help. What would be the best cheap amps, 3 way seps, crossover and subs you could suggest. What I have in mind is firland amps, dls seps, any 3 way crossover and image dynamics 8" subs.
Sir mawalang galang po pa interrup sa inyo ulit... Sir medyo complicated ang plano ninyo more likely maraming kang makukuhang problema pagganyan set-up mo.. make your set-up simple as much as possible..two decent amps a "2 channel amps" and a "4 channel amp" or 1 mono amp and a 4 channel amp(if you dont want the 5 chanel amp)this will solve your problem.. dont worry at the moment with the ACTIVE x-over..and why not to worry coz if you buy this 3 way components already includes passive x-over.. just connect it straight to your 4ch amp(frnt/rear) and let the amps x-over do the job to cut the frequency.(wag yong mga generic na amps po sir dahil lalo sasakit ang ulo mo hindi reliable ang x-over nito) the 2nd mono-channel amp will power your sub.. Dont use your headunit alone to power the rear speakers (kung ito sa isa sa mga plano mo) more likely it will peak or clip soon enough..dyan ka magproblema baka hindi mo yan mamalayan nanagclip napala ang lingkod dahil sa lakas ng front ends mo..always use an amp the more power youll give to your speakers the cleaner it sounds..
"What if I do it like this I'll get one 3 way active crossover to filter the frequency for my 3-way speaker. "
if this is the case you will need more amps(3 amps or 1 2-chan for tweeters and a 4-chan for mid and woofer) for the front, 1 amp for the rear and another amp for the sub..:nerves: sir again make it simple..
choosing a speakers it will depend on how much you want to spend and kung ano ang comfortable sa tinga mo and would go for line-driver(it will help boost the signal from your HU) instead po sir ng Active X-over dahil yong 4volts mo sa HU hindi nayan 4volts pagdating sa amps mo at lalo lagyan mo pang active xover.. para walang regrets magaudi ka at pakkingan mo ang details bawat spkears sir ..dahil nangyari na sa akin ito may nagsuggest sa akin na brand (mamahalin) pinakinggan at nagustuhan ko pero my only mistake was im so anxious and cant wait..meron pa pala masganda at mura pa.. good luck
