Quote Originally Posted by Pajerokid29 View Post
What head unit are you planning to use? because not all 6 preout H/U are full active capable, some might just be a 2-way active H/U which controls you Highpass and lowpass but you would also need to control your bandpass (the gap between the HPF and LPF) and check up to what frequency your HU can go from it's LPF to it's HPF, may iba kasi na may HPF nga pero until 125HZ lng, as for your question kung ok na ang V12? on paper yes, pero it's up to you, I'd suggest a good four channel amp. as for wiring them, are you planning to connect the sub sa V12? if so then tama ka, 7 channels would do. here's how it shoud look like: 1st V12 amp (4ch) CH1 & CH2 - Tweets with HPF set at around 1KHZ or higher, CH3 & CH4 - Full-range (vocal), 2nd V12 amp CH1 & CH2 Midbass, CH3 and CH4 bridged to power the sub.if I were you, yung rear speakers ko kakabit ko sa amp, yung tweeter can share the channels for your front vocals since high frequency naman pplay nila e, you can wire the vocals and midbass i parallel to cut the resistance in half for your V12's to produce twice its power, just make sure your speakers won't give your amp a final ohm reading of 1 or lower kasi AFAIK, 2-ohm stable lang ang V12's. kung taga south ka lang maybe I can help you.
Thank you sir pajerokid for the reply. Yung HU na makukuha ko is not capable of full active pala e. it has 6 pre outs but two of each lang front, rear, and sub. What if I do it like this I'll get one 3 way active crossover to filter the frequency for my 3-way speaker. Then I'll set the crossover to front only then from there I'll filter the frequencies for tweeter, vocals and mid bass. then for the rear speakers I'll directly get the line from the headunit same goes for the subs. but the sub will definitely go through an amplifier. but for the rear it may or may not pass an ampli. if this would work would I still be needing the passive crossover that goes with the 3 way seps. thanks again for the help. What would be the best cheap amps, 3 way seps, crossover and subs you could suggest. What I have in mind is firland amps, dls seps, any 3 way crossover and image dynamics 8" subs.
