Results 11 to 16 of 16
November 10th, 2011 09:50 AM #11
Nasa box design po mostly, the port tuned from 37hz to 45hz, and you have to made harder inclosure without air leaks except the port to get hard hitting bass, if you want to feel the bass up to the next block, you have to get serious sub woofer, a 18" and a 2000 watts power handling is a good choice, syempre, along with the serious power supply.
For example:
http://a8.sphotos.ak.fbcdn.net/hphot..._5234539_n.jpg
November 10th, 2011 11:12 AM #12
- Sep 2011
- 769
December 31st, 2011 05:35 PM #14
I've never heard of Firland Audio before, all I can say is mas mahal pa sa mas kilala at higher end for the same power range. Comparing the price of my Alpine MRX-M100 (600W RMS * 4ohms and 1000W*2ohms) vs Firland Audio XL2000D (700W RMS * 4 ohms and 1300W * 2 ohms, "sana nga!". Most amplifiers are overated so that consumers will buy their product but not the Alpine products which is under rated according to test and comments of users, and so puts out more power than what is says on the box. MRX-M100 actually produces over 1200W * 2 ohms and sound quality is amazing, so I'll stick with my Alpine!
- Nov 2009
- 351
January 12th, 2012 02:47 AM #15I just had my car audio set up using an all-Firland system, and my initial impression is wow! Total bang for the buck! I don't like spending a lot of money only to be disappointed or to be underwhelmed. My Firland system has exceeded my expectations in car audio at a very reasonable price. The voices and instruments are very clear, and the amps are doing a good job powering the speakers. Firland Audio's quality is top notch considering it price.
Highly recommended brand.
- Feb 2009
- 1
January 19th, 2012 02:12 AM #16
high idle RPM at engine start
