Results 1 to 10 of 76
December 5th, 2018 06:48 PM #1
Pahingi naman ng inputs. Mga 50K lang max budget.
Stage 1.
Component : Polk audio db6502 ~ 10K (may polk audio rti a3 kasi ako sa bahay. ok naman yung sound nya para sa akin kaya iniisip ko na polk audio din sa oto)
Head unit: Pioneer DEH-80prs ~ 15K
Deadening ~ 2K
Dash Kit ~ 1.5K
Install ~ 1K
Stage 2.
Amp (wala pang naiisip)
Install ~ 3K
Stage 3.
10 inch sealed sub ~ 8K.
Kung may mga gears dyan na pwede installment pwede na siguro sabay sabay sila lahat.
Yung HU is capable of 3 way active kaya gusto ko din sana gamitin sa future. Malaki ba difference ng 3 way active sa passive?
Ano suggestions nyo?
December 5th, 2018 08:20 PM #2
parang maliit budget mo sa amp kung 3k, mas mahal pa ang subwoofer mo. kung 3-way active prefer mo dapat 5ch Amp ang kunin mo para tig-iisa kada speakers mo saka 1 para sa subwoofer.
papalitan ko ang DEH-80PRS headunit ng kotse ko this Dec at papalitan ko ng touch screen. if gusto mo ng pre-owned pm ka lang...
December 5th, 2018 08:27 PM #3
A full active 3-way setup would require 2 4-channel amps or a 6-channel amp plus a mono amp or a single 8-channel amp, and the active crossovers to segregate the frequency cutoff points. Not to mention you will need a 3-way component speaker set (tweeters, mids, and mid-bass).
A 2-way active setup is easier to build as you just need a decent 5-channel amp together with an active crossover. Two channels for the tweeters, two channels for the mids, and the mono channel for the subwoofer.
Sent from my iPhone using TapatalkLast edited by Egan101; December 5th, 2018 at 08:31 PM.
December 5th, 2018 09:01 PM #4
December 5th, 2018 09:07 PM #5
Ay mali. ~ 10k sa amp. 3k yung estimate ko sa install.
Edit ko post. :D
December 5th, 2018 09:14 PM #6
How about yung separates sir? Ok na kaya yun? Gusto ko din sound signature ng grado headphones. So kung pwede sana na ganon ding sound.
- Sep 2006
- 143
December 6th, 2018 09:07 AM #8
December 6th, 2018 09:56 AM #10
An SQ 2-way or 3-way full active setup would need a really good amplifier to make the speakers sound well. Most amps at that price range don't have the features to build a full active setup without buying the separate processor or crossovers for segregating the cutoff frequencies. At that price range, I would suggest a decent 4-channel amp and setup your system to ran passive (2 channels for the seps, 2 channels bridged to the sub).
Also, a full active setup would require more speaker wires meaning more costs for the setup. A full active 2-way would require almost twice the set of wires compared to a passive two-way. Even more so with a full active 3-way setup.
Long before, I built a 2-way full active setup around a DLS CA51 5-channel amplifier. It was the heart of my system as it has a built-in active crossover.
A 3-way active setup would need tweets, mids, mid-bass, and a sub. Each speaker will have to be powered separately and each pair has to be set to specific cutoff frequencies.
i'm not sure if it's the same as the installation of the rear cam procedure. iirc, yung sa akin...
