Page 1 of 4 1234 LastLast
Results 1 to 20 of 76
    Pahingi naman ng inputs. Mga 50K lang max budget.
    Stage 1.
    Component : Polk audio db6502 ~ 10K (may polk audio rti a3 kasi ako sa bahay. ok naman yung sound nya para sa akin kaya iniisip ko na polk audio din sa oto)
    Head unit: Pioneer DEH-80prs ~ 15K
    Deadening ~ 2K
    Dash Kit ~ 1.5K
    Install ~ 1K
    Stage 2.
    Amp (wala pang naiisip)
    Install ~ 3K
    Stage 3.
    10 inch sealed sub ~ 8K.
    Kung may mga gears dyan na pwede installment pwede na siguro sabay sabay sila lahat.
    Yung HU is capable of 3 way active kaya gusto ko din sana gamitin sa future. Malaki ba difference ng 3 way active sa passive?
    Ano suggestions nyo?
    Apr 2012
    Quote Originally Posted by robot.sonic View Post
    Stage 1.
    Deadening ~ 2K
    Dash Kit ~ 1.5K
    Install ~ 1K
    Stage 2.
    Install ~ 3K
    Stage 3.
    parang maliit budget mo sa amp kung 3k, mas mahal pa ang subwoofer mo. kung 3-way active prefer mo dapat 5ch Amp ang kunin mo para tig-iisa kada speakers mo saka 1 para sa subwoofer.
    papalitan ko ang DEH-80PRS headunit ng kotse ko this Dec at papalitan ko ng touch screen. if gusto mo ng pre-owned pm ka lang...
    A full active 3-way setup would require 2 4-channel amps or a 6-channel amp plus a mono amp or a single 8-channel amp, and the active crossovers to segregate the frequency cutoff points. Not to mention you will need a 3-way component speaker set (tweeters, mids, and mid-bass).
    A 2-way active setup is easier to build as you just need a decent 5-channel amp together with an active crossover. Two channels for the tweeters, two channels for the mids, and the mono channel for the subwoofer.
    Apr 2012
    i stand corrected, 6ch saka 1 mono amp na pala kapag 3-way full active.
    Ay mali. ~ 10k sa amp. 3k yung estimate ko sa install.
    Edit ko post. :D
    How about yung separates sir? Ok na kaya yun? Gusto ko din sound signature ng grado headphones. So kung pwede sana na ganon ding sound.
    Di ba considered na 3 way active yung highs, mid, at sub?
    Sep 2006
    di pa po... 3 way component speakers have highs, mids, and low... which is different from a sub
    Quote Originally Posted by mortis View Post
    Alright sir. Thanks.
    Edit ko post. :D
    An SQ 2-way or 3-way full active setup would need a really good amplifier to make the speakers sound well. Most amps at that price range don't have the features to build a full active setup without buying the separate processor or crossovers for segregating the cutoff frequencies. At that price range, I would suggest a decent 4-channel amp and setup your system to ran passive (2 channels for the seps, 2 channels bridged to the sub).
    Also, a full active setup would require more speaker wires meaning more costs for the setup. A full active 2-way would require almost twice the set of wires compared to a passive two-way. Even more so with a full active 3-way setup.
    Long before, I built a 2-way full active setup around a DLS CA51 5-channel amplifier. It was the heart of my system as it has a built-in active crossover.
    A 3-way active setup would need tweets, mids, mid-bass, and a sub. Each speaker will have to be powered separately and each pair has to be set to specific cutoff frequencies.
    Thank you Sir Egan101.
    Ano recommended nyo na separates sir? Ang basis ko lang sa polk audio ay yung bookshelf ko sa bahay.
    Based sa pag basa basa ko, considered na "bright" daw yung RTI A3 na bookshelf and ganon din yung grado na headphones. So siguro nga preferred ko yung bright sounding speakers.
    It would be best not to compare headphones to car audio equipment as the setup is entirely different. Even home audio setup is different compared to car audio.
    Your choice of Polk Audio db6502 is good enough, a notch higher in quality against cheaper options like JBL. If you ask me, I have high regard to DLS, Focal, and Morel speakers.
    OK Sir. Salamat.
    OK Sir. Salamat.
    Give Mickey's a visit in his shop in Marikina. He has a lot of good stuff to sell. Just don't blame me if you find yourself spending much more. Hehehe
    Chinecheck ko website nya sir. Dun ako kumukuha ng price reference and anong gears ang available sa market natin.
    Pero baka kay jeff tan ako magpa install kasi ok yung install nya sa dating oto ko. Nag try ako sa iba kaso na disappoint ako.
    Oks talaga yan si Jeff, madali kausap tapos di taga sumingil. Pareho ko sila pinupuntahan ni Mickey kapag car audio gears pinag-uusapan.
    Medyo kulang lang line up nya ng gears. Sa Audio Excellence pa ako kukuha ng polk audio. 9990 ang retail price pero pag cash day 9K na lang.
    Apr 2012
    sa mickey's din ako nagtingin ng presyo kapag may gusto ako i-check pero outdated na ibang items. i often look at their FB pages too like mickey's, jc car audio, simplesound, timsaudiogarage, questcaraudio, musico mobile, jetcar, candyshop, c&j, 2mc...etc. kaya updated ako ng mga latest installs nila. yun nga lang may tendency makagat ka ng updrade bug if you frequent their fb pages i follow few of them na lang like mickey's, jc car, tim's at simplesound. natutuwa na lang ako tingnan yung mga bagong installations nila
    Mar 2012
    Dagdagan mo konti budget mo if you want to go full active and get an amp that has the lowest THD you can afford if SQ habol mo. If you want to get the full potential ng 3way mo maganda pag may DSP. Sa 3way with dsp setup, sound signature ng driver manufacturer ay insignificant dahil sa kamay ng maayos mag tono. They can make bright speaker sound warm or make a warm sounding speakers sound bright.
    Honestly, most of the general public cant distinguish the difference between a 2way vs 3way system if hindi makita ang mga speakers and installed properly. Unless you have an audiophile ears na maka distuinguish ng mga tiny details sa sound reproduction.
    Thank you sirs.
    Stick na lang ako sa basic setup. Haha
    Mukhang ok na yung stage 1 plan ko. polk audio 6502 + deadening + hu muna.
    Next na iisipin ko ay kung saan ko pwede itago yung amp.
CRV SQ Setup
