Results 1 to 20 of 76
    A full active 3-way setup would require 2 4-channel amps or a 6-channel amp plus a mono amp or a single 8-channel amp, and the active crossovers to segregate the frequency cutoff points. Not to mention you will need a 3-way component speaker set (tweeters, mids, and mid-bass).
    A 2-way active setup is easier to build as you just need a decent 5-channel amp together with an active crossover. Two channels for the tweeters, two channels for the mids, and the mono channel for the subwoofer.
    Apr 2012
    i stand corrected, 6ch saka 1 mono amp na pala kapag 3-way full active.
    Ay mali. ~ 10k sa amp. 3k yung estimate ko sa install.
    Edit ko post. :D
    How about yung separates sir? Ok na kaya yun? Gusto ko din sound signature ng grado headphones. So kung pwede sana na ganon ding sound.
    Di ba considered na 3 way active yung highs, mid, at sub?
    Sep 2006
    Quote Originally Posted by robot.sonic View Post
    di pa po... 3 way component speakers have highs, mids, and low... which is different from a sub
    Quote Originally Posted by mortis View Post
    Alright sir. Thanks.
    Edit ko post. :D
    An SQ 2-way or 3-way full active setup would need a really good amplifier to make the speakers sound well. Most amps at that price range don't have the features to build a full active setup without buying the separate processor or crossovers for segregating the cutoff frequencies. At that price range, I would suggest a decent 4-channel amp and setup your system to ran passive (2 channels for the seps, 2 channels bridged to the sub).
    Also, a full active setup would require more speaker wires meaning more costs for the setup. A full active 2-way would require almost twice the set of wires compared to a passive two-way. Even more so with a full active 3-way setup.
    Long before, I built a 2-way full active setup around a DLS CA51 5-channel amplifier. It was the heart of my system as it has a built-in active crossover.
    A 3-way active setup would need tweets, mids, mid-bass, and a sub. Each speaker will have to be powered separately and each pair has to be set to specific cutoff frequencies.
    Thank you Sir Egan101.
    Ano recommended nyo na separates sir? Ang basis ko lang sa polk audio ay yung bookshelf ko sa bahay.
    Based sa pag basa basa ko, considered na "bright" daw yung RTI A3 na bookshelf and ganon din yung grado na headphones. So siguro nga preferred ko yung bright sounding speakers.
CRV SQ Setup
