Page 1 of 3 123 LastLast
Results 1 to 20 of 42
    Aug 2011
    mga sir, pwede po ba gamitin ang speaker with subwoofer ng jvc component system at ikabit sa sasakyan? kung pwede ano kailangan gawin?
    Check the impedance and power capacity of the speakers. If they match then you're good to go.
    Aug 2011
    impedance is 6ohms and power capacity is 100w sir. is this okay?
    Aug 2010
    And how did you measure it?
    At ano meaning mo speaker with subwoofer ng JVC component system? I hope these are just the speakers themselves not the speaker cabinet and all.
    In any case, just pluck out the speakers and use it for your system. Pwede ba? Yes. Component system drivers usually present a lighter load than car drivers anyway. But pay attention to passive crossovers that might be included in the tweeter and midbass drivers.
    Aug 2011
    Quote Originally Posted by jhnkvn View Post
    meron po nakalagay sa likod ng speakers sir . gusto ko kasi gamitin un as my bass if pwede sa sasakyan. dalawa ung speakers with subwoofer.
    Aug 2011
    jvc.jpg yan po sir pic ng speakers
    ^ Just as I've thought, you really are referring to speakers of Home Theater Systems (HTS).
    And how do you intend to place it in your car? Balak mo bang kalasin 'yung mga speakers
    then place it on a fabricated enclosure inside the car? Or place in the car as is?
    Ang alam ko sir TS, maganda ang tunog niyang mga "component speakers" because
    of the enclosures. At saka 'pag binuksan mo 'yan, may mga electronic parts sa loob
    like resistors, capacitors or something. Hindi ko lang alam kung ano tawag sa mga
    small parts na 'yon. Yung iba nga may mga parang "bulak" lining pa sa loob.
    Ang advise sa akin ng mga shops / ka- tropa, keep na lang the HTS speakers (use them somewhere else),
    then bumili na lang ng mga amplifiers, subwoofers, speakers, etc. na para talaga sa mga sasakyan.
    Magpagawa na lang ng enclosure that will bring out the best performance of you speakers
    and at the same time, add a "dashing" look to your car.
    ps
    pag may time ka, try visiting this thread
    http://tsikot.com/forums/car-audio-v...0/index95.html
    you'll see alot of sir jhnkvn's very valuable post / advises.
    Aug 2011
    di na kasi nagagamit ung component namin. kaya balak ko lang gamitin ung subwoofer ng component. ok lng naman sa akin kahit d masyado malakas ung bass . ng palit na ako ng speakers ung pioneer 2-way gamit ko ngayon at ng install narin ako ng tweeters. still on stock head-unit fujitsu ten brand. intend ko lng ilagay sa likod ng revo ko.. medyo low on budget kaya opt ko nalng is to use those component speakers if pwede.
    ang dami ko rin kasing mga component speakers. JVC, SONY, PIONEER, etc.
    karamihan dala ng mga tiyuhin kong nagpunta sa middle east.
    kaya naisip ko rin 'yan noong hindi ako makuntento sa sound systems ng mga
    saasakyan namin. kaso, nung alisin ko sa mga original enclosures at sampolan ko
    sa mga fabricated enclosures, lalong pumangit ang tunog!!! indescribable!!! :bwahaha:
    wala pa akong nababasa sa mga threads dito na merong naglagay ng ganyan sa mga kotse nila.
    ang sagwa nga naman 'pag nasa original enclosure at kitang- kita sa loob ng sasakyan.
    pero 'yung lumang toyota tamaraw namin (early 90's edition pa :freak: ),
    nilagyan ko ng isang pares sa ilalim ng upuan. at sinamahan ko ng amplifier,
    ang lakas ng tunog!!! ang ganda ng hataw!!! parang mga speakers sa perya pag fiesta. :bwahaha:
    btw
    meron din ako BOSE Acoustimass 5 Speakers (Series II and Series III) - di rin nagagamit.
    maganda ang enclosures ng mga bass modules, kaya lang hindi rin maganda tunog nung
    i- try ko ikabit doon sa subwoofer line ng car. bitin sa kalabog, hehehe.
    'yung 2 old cars namin, pinalitan ko lang ang stock speakers ng mga 3-way at 4-way speakers.
    siyempre, mas gumanda na ang tunog. simple and satisfying...
    Maybe TS just wanna avert the cost of upgrading thats why he's trying to make use of component speakers that might be sitting around the house. If form is no issue then hes a free man to mount the speaker box anywhere in the vehicle.
    TS. Check the output impedance of your headunit/ amplifier usually range says 4 to 8ohms, n watts..If your component speakers falls in that range then it could be done, just use some goodspeaker wires. Dont mind the electronics inside, as long as input impedance meets your requirement then its good to go.The electronics inside speakers is just a crossover network hi-mid-low pass filters to direct w/c frequency goes to what speaker(woofer, midrange, tweeter).
    Aug 2011
    thank you sa mga inputs nyo mga sir. do i need an amplifier pa ba regarding this matter?
    nope. kung ganyan setup mo, baka di kayanin ng speakers.
    or you can go the shorter route, an amplified subwoofer.
    parang ito.
    merong binebenta sa sulit na wala pang 4k... dunno the quality though.
    Infinity Basslink 10" Amplified Subwoofer - Secondhand For Sale Philippines - 37569948
    pag ganyan setup mo, reasonable separates lang, tweeters and a good head unit....
    Aug 2011
    wala pang budget as for now para pambili. will get a subwoofer soon if magka pera na. hehe
    Given na within range ang impedance, car stereo power output would normally be around 50w per channel so kakayanin ng speakers mo.
    Para makasiguro ka, chek mo muna output impedance ng headunit at power output.. Anong model ng headunit?
    Aug 2011
    Fujitsu ten E3301CSC. stock HU ng revo 2004. nakita ko pala specs nya. nakalagay dito 43W x 4ch. impedance 4 ohms. baka di pwede ung sa component kasi 8 ohms yun.
    Jul 2006
    Quote Originally Posted by jncp9886 View Post
    Pang bahay yata ito?
    Aug 2011
    yes po. hehe
    Sep 2012
    Nagawa na yan ng isang barkada ko same speaker na nasa pic mo
    Nilagyan lang nya ng ampli then nasa trunk nakalagay. Pumping up the volume alog ang kalampag sa sasakyan
    Note: Isang speaker lang yung kinabit nya kasi ubos trunk space pag yung dalawa nilagay
    Aug 2011
    Quote Originally Posted by jodski View Post
    ang galing ah. ma try nga. hehe
    Usually ang amp na 4ohms output impedance kaya i-drive ang 8 ohms speakers pero don't expect full power. Umiinit ang ampli sa standing waves kung lower speaker impedance ang nilagay mo say 4ohms ampli connected to 2 ohms speakers.
    If you wanna be safe since dalawa naman ang speakersi, i-parallel mo nalang to get the 4 ohms requirement ng amplifier.. OR.. use matching transformer to adjust the impedance.. Pero right now ang pinaka safe para ma-test mo ay i parallel yung speakers then connect to 1 channel out ng HU.
component speakers.
