Results 1 to 10 of 13
September 22nd, 2010 01:59 PM #1
Bros,
Tanong ko lang kung compatible tong setup ko.
Eto specs ng seps (ads236dh)
RMS: 100 Watts
Impedenace: 4 Ohms
Max Power : 250 Watts
Eto specs ng Amp (Sony Xplod XM-4S)
RMS Power: 50 Watts
Peak Power: 90 Watts
Minimum Impedance Bridged: 4 Ohms
Eto specs ng Sub: (PolkAudio db840 in sealed box)
RMS Power: 180 Watts
Impedance: 4 Ohms
Match ba tong mga to?
Dati kasi parang ok lang yung tunog. Pero ngayon parang di ko na gusto.
Kung di match, ano kaya ang dapat kong palitan? Amp? Seps? o Sub?
Salamat
robot.sonic
- May 2010
- 143
September 22nd, 2010 08:32 PM #2
sir kulang sa power o wattage ng amplifier mo.......
kaya ang kalalabasan n tunog nyan ay hindi busog.......
kung titingnan mo sir sa subwoofer mo pa lang
di na sasapat ang amplifier mo
sa 180w mo na woofer 50w lang ang papasok n power galing sa amplifier mo
ang maganda niyan sir magpalit ka ng amplifier....
at isa pa sir mas maganda kung dalawng amplifier gamitin mo
isa sa seps at isa sa subwoofer mo.......
September 22nd, 2010 08:40 PM #3
Kulang ang power ng amp mo para sa seps at sub sir. Kung gusto mo yang sony xplod amp mo ilagay mo na lang sa seps mo at bili ka na lang ng mono amplifier mo para sa sub. (Nasasayangan lang sa gears. Hehe.) Or ibenta mo na lang yan at bili ka ng one of these amps
http://www.mickeysautosound.com/multi-channels.html
I recommend the Sound Magus C160.
Functions:
4X160Wrms Class-AB amplifier.
2 ohm load stable.
Double Side PCB and SMD components.
Adjustable Input level, LPF, HPF.
Advanced short circuit, overload, over heat and low voltage protection.
2-channel mode switch available.
Gold-plated isolation terminals.
C160 Specifications
4 Ohm *14.4V RMS Power THD+N <0. 1%
160W ¡Á 4CH
2 Ohm *14.4V RMS Power THD+N < 0.1%
190W ¡Á 4CH
4 Ohm *14.4V Bridged RMS Power
350W ¡Á 2CH
HPF Frequency
50~500Hz Adjustable
LPF Frequency
50~500Hz Adjustable
Frequency response
10Hz~25kHz
Channel separation
>89dB
Input Level
0.2V-5V
Buffered RCA output terminals
A Channel
Operating voltage
DC10V-16V
protection
Short circuit, Over-voltage, Reverse polarity, Thermal
High-grade Nickel-plated, heavy duty terminal block type connectors
Yes
Isolated, gold plated speaker and power terminals
Yes
Dimension(mm)
53x228x347mm
Or you could buy a JBL amp.
PS: Hindi ako connected with mickey's autosound neither sound magus and JBL. Hehehehe.
September 23rd, 2010 11:38 AM #4
Kahit hinde ako nagpapatugtog ng malakas bro kailangan ko ba talaga mag upgrade ng amp?
Plano ko pa naman sa december mag upgrade ng Polk Audio db6501 na seps.
Hmmmm.... Baka may interesado dyan sa sony xplod xm-4s. Benta ko ng murang mura.Bentang adik!
- Jun 2009
- 27
October 16th, 2010 01:51 PM #5mas mataas dapat ang wattage ng amp kesa sa speakers and subs para laging busog di nagaralgal
October 16th, 2010 02:38 PM #6
Pag mas mababa kasi wattage ng amp . at mataas ang sa speaker hirap ito at madaling mag init amp. at hindi maibibigay ang magandang tunog ng speaker.
November 3rd, 2010 10:36 PM #8
hmmm... nice seps you have there robot.sonic
yung front seps ko; 80W nominal, 160W max input
driven by a 4x50W RMS rockford fosgate amp, MBquart seps rear * 75W nominal, 120W max
within tolerance/safe range pa naman sila and both sounds great, though i know na mas may ibubuga pa sila kung mag-upgrade ako ng mas powerful na amp para dito, busog sabi nga nila and it's true...
btw, there's no such thing as overpowered speakers(as a lot of people think ed of)... mas masama pa i you are cranking up your speakers with an underrated/too low wattage amp, result; speaker damage
- Jul 2008
- 39
January 18th, 2011 10:59 PM #9need help mga sir! same problem din. i have a alpine old school amp 3523 40watts x2, gusto ko sana gamitin sa targa seps x652 ko. ok lang kaya yun? thanks!
January 19th, 2011 09:20 PM #10
I wouldn't recommend trying to breathe life into used amplifiers. Eventually, you'll have to replace them. So I'm a no on that.
It will depend on the specific vehicle/battery designs on making it feasible but some(Tesla and...
Mitsubishi Xforce
