Results 11 to 16 of 16
July 8th, 2004 06:39 PM #11
with an S12L7, would it cover up my JBL Stock seps? isa pa... if I do get an s12L7 would it still be heard if I put it in the back of my pickup bed? I'm considering getting a big one then at the same time taking off the glass in between the cabin and the camper shell then joining both with a sealant or something else.
what's your opinion on this?
July 8th, 2004 07:06 PM #12
ganyan din sana ung idea ko sa pick-up namin, kaso baka nalubak ng malakas maghiwalay ung nagdudugtong sa cabin and campershell...
July 8th, 2004 08:56 PM #13
naku, baka masmalaking problem pa pag patanggal mo yun glass... mahirap talaga lagyan ng 1ft sub(12 inch hehehe) ang pickup... baka pwede yun 2 s8l7 sa likod ng seats... kaso maliit lang yun space dun... may 97 strada kami dati and space is really limited. baka pede 3 round na 8 inch? or 2 s8l7's? or 4 na 6" subs? hehehe im just guessing. it's best discussed with a professional installer
Tsikot Member Rank 4
- Feb 2004
- 1,704
July 9th, 2004 12:02 PM #14you might be able to get away with two 10 inch subs pero yung round lang. the problem with the square subs is their magnets are so big na mahihirapan ka sa mounting depth.
i think in a strada, one or two ten inch round subs will be more than sufficient.
andy
July 11th, 2004 03:07 AM #15
the connection between the camper and the cabin will most likely be somewhat like a duct made of rubber. something like the ones in an l300. I still have to ask if that's possible.. .
The 2 S8L7's will be ok at the back of the rear seats. According to Intense its possible. He has done the setup already on one of his customers.
It's either an S12L7 at the pickup bed with the glass out and the cabins connected or go for the the subs at the rear seats.Which would be better? hehe
- Feb 2004
- 1,704
July 12th, 2004 09:47 AM #16i would go for in-cabin pare. aside from being safer and less hassle. it will be cheaper din because you don't have to get a huge amp that the s12L7 requires.
i would even recommend a pair of round subs, maybe a pair of 10 inch comp VRs (if you want kicker talaga). i like the sound of the roud subs better than the square ones kasi (personal opinion lang ito)
andy
This is only applicable for low mileage cars, right? If pudpod naman na yung harap, then that means...
2018 Subaru XV - needs urgent tire replacement
