Results 131 to 139 of 139
- Aug 2005
- 35
September 14th, 2005 04:32 PM #132curious lng yung all targa ba hindi lalagpas ng 10k? excluding HU. ano n ksma nun, 2 or 3 way seps, amp, sub? or coax?
- Sep 2005
- 22
September 19th, 2005 01:02 AM #133yehey!!!! im having my cars audio set up setup this week, im getting the new ipod nano din so! cant wait to listen to my ipod in my car with the new setup!
btw, if u guys are looking for nanos i have a source selling them at 15k for the 4gb and 12k for the 2gb!!! hehe, baka gusto nyo din.
il post my set up before the week ends!
- Nov 2005
- 2
November 3rd, 2005 12:42 PM #134Why not try the acoustic vertus seps...they are pretty good...im a user and pretty happy with it specially if your purpose is for SQ and the price isnt that bad....
- Jan 2009
- 4
January 29th, 2009 03:30 PM #135ei mga pare patulong naman plan q audio set up yung auto q e 2003 nissan sentra gx kaso wala pa q alam kung anu mga bibilhin q from the head unit gusto q sana SPL na my konting SQ thanks ha!
- Feb 2014
- 1
February 8th, 2014 10:15 PM #136Kenwood amplifier KAC-HQR8400
Maximum Power Output720W
CEA Spec.
60Watts x 4 at 4 Ohms and 1%THD+N
85dBA (Reference 1Watt into 4 Ohms)
Rated Power
60WattsRMS x 4ch at 4 Ohms
90WattsRMS x 4ch at 2 Ohms
60WattsRMS x 2ch + 180Watts RMS x 1ch at 4 Ohms
General Features
Variable Low Pass Filter (50-200[Hz], -12dB/oct)
Variable High Pass Filter (50-200[Hz], -12dB/oct)
Bass Boost (40[Hz], +18dB) only Bch
Size: W 330mm x H 55mm x D 215mm
pa help Sa Setup ng Sounds Ko ano magandang combination na speaker para sa Kenwood Amplifier ko gusto ko ung maganda ung bass advance tnx sir/mam
- Apr 2012
- 58
February 10th, 2014 07:10 PM #137mga sir, patulong naman sa sound setup. I have a 2004 BMW 318 and naka stock na sound system siya currently.
nagpa quote ako sa mickey's and below yung nirecommend kanina:
Infinity Kappa 5" - ~9k
Sonus Ecstatic ~13k / Rockford ~20k
Alpine 9887 (slightly used) ~10.5k
Sub focal/morel 10" ~8-9k
Labor ~8.5k
All prices are just estimates and pwede pang babaan.. it was just a 15-minute chat nung dumaan ako kanina.
What do you think guys? Ano bang recommended na setup?
mejo trip ko yung alternative/house music.. and preferrably mejo bumabayo sana yung sounds.
thanks gurus!
February 10th, 2014 09:01 PM #138
You failed to ask how much Mickey charges sa tuning niya.. you won't take advantage of the 9887 unless you do.
Second is that you can't lower the prices of products by much since it's regulated by the distributor mismo. If you want to start haggling, doon ka sa labor and services ;)
I'll go hit you back a longer reply later.
February 11th, 2014 01:23 AM #139
You're off to a good start. First thing you might want to do is head to Kotseaudioclub.com's forums and start reading. Just take maybe 3 days to back read and try to absorb as much knowledge as you can.
1. I'm not fickle on what your speakers are -- it's hard to get 5" speakers as most speakers are manufactured on a 6.5" diameter basis. Give Mickey your budget, ask what are your options, then choose among those.
2. The Alpine 9887 is highly recommended. Your next option will be the newer Pioneer 80PRS which retails at 16,000php SRP.. sadly, since it's still relatively new, secondhand prices are still fairly high. You can sometimes spot secondhand CDA-9887s at KAC's ICE selling section and going price is at 7,000php to 10,000php.
3. For the subwoofer, truthfully.. I'm not much of a subwoofer guy. Subwoofer performance is highly dependent on enclosure. You don't pick a subwoofer then pick your enclosure to fit your needs.. it's actually the opposite way around. Mickey's preference will probably be the Focal Performance subwoofer or the Morel Primo -- both are very good subwoofers (I prefer the Morel in this case) on a sealed box.
3.1. If you can go for 12", go for a twelve over a ten. Reason for this? More surface area = more efficient at moving air = more bass.
3.2 For your budget, personally I'll lower the subwoofer's budget. If you want to go for something lower but not too low, I'll vote for a JBL GTO1214 subwoofer. That should free up around 5,000php from your budget for other allocations.
4. Your amplifier will depend on how Mickey plans on wiring your system. From the looks of it, he'll probably tap the 9887's built-in amplifier for the tweeters, run the midbass on two of the amplifier's channel (4-channel amplifier), and bridge the other two for the subwoofer.
4.1 You will run full-active in your system. Because if you don't, you're not utilizing your CDA-9887's processing capabilities.
5. Try to note of all other miscellaneous expenses such as subwoofer enclosure costs. Then you also have to budget for wiring costs (again, ask for your options at your budget), labor, woodworks, and lastly tuning costs.
