Results 1 to 10 of 29
July 10th, 2006 04:14 AM #1
Tanong ko lang peeps...
Yung boom boom ng auto ko seems to stay inside the car lang, wala sa labas unless buksan ko yung trunk. Malakas naman pag nasa loob ng auto.
Naka +3 sa eq ng bass, 6db sa super bass and about half ang gain sa amp. v12 705 po ang amp and aura 12000 rpm ang sub in an abc box, nakaharap palabas ng trunk.
Bakit po pag nasa labas ako ng auto parang nagpapabayo ako ng tweeters, pero sa loob naman boomboom na? Meron ba kong pwedeng galawin sa settings para lumakas to? Thanks.
July 10th, 2006 04:38 AM #2Originally Posted by the_noise
July 10th, 2006 05:21 AM #3
Need mo na sub yung gumagapang ang bass. Pag puro tigas lang, di masyado marinig yun sa labas.
July 10th, 2006 02:26 PM #6Originally Posted by the_noise
bro yung subs mo ba nasa trunk? basically, what you need to do first is to position your subs outwards. baka ngayon, yung sub mo eh naka point in papasok ng car kaya andun ang bayo.
kung wala pa din, tingin ko nasa settings na ng EQ and gains yan....
July 10th, 2006 02:54 PM #7
Mataas na gain settings mo, so i don't think there's any problem with that. You go any higher than 1/2 (gain settings) baka mag overheat amp mo. It could be the design of the box, gaano ba kalaki? Can you specify the dimensions? baka masyadong maliit.
try mo sub pointing forward, ported or sealed ang box?
July 10th, 2006 09:04 PM #10
Outward facing na yung sub. I think the box size is fine though. Here's the pic.
Di makita yung buong trunk sa pic e, basta 12" yung sub so dun nyo na lang i-scale yung size nung box. Also, can't tell you much about the depth of the box either, pero hindi sya maliit hehe
We previously supported Tapatalk for Google Play and iOS store, but both are unsupported right now....
tapatalk smart phone application.
