Results 1 to 20 of 29
    Oct 2003
    Tanong ko lang peeps...
    Yung boom boom ng auto ko seems to stay inside the car lang, wala sa labas unless buksan ko yung trunk. Malakas naman pag nasa loob ng auto.
    Naka +3 sa eq ng bass, 6db sa super bass and about half ang gain sa amp. v12 705 po ang amp and aura 12000 rpm ang sub in an abc box, nakaharap palabas ng trunk.
    Bakit po pag nasa labas ako ng auto parang nagpapabayo ako ng tweeters, pero sa loob naman boomboom na? Meron ba kong pwedeng galawin sa settings para lumakas to? Thanks.
    Sep 2005
    Quote Originally Posted by the_noise
    Try KotseAudioClub. They can give you a much deeper insight on your query.
    Feb 2006
    Need mo na sub yung gumagapang ang bass. Pag puro tigas lang, di masyado marinig yun sa labas.
    Oct 2003
    lagyan mo 2 "15 inch with at least 1000 watts mono amp.
    Quote Originally Posted by cablespy
    this oughta solve the problem.
    like sir flagg said, i think you're looking for rolling bass, if you wanna be heard outside. kelangan mo ng dalawang kinse with enough power to push 'em.
    try mo sub pointing forward, ported or sealed ang box?
    bro yung subs mo ba nasa trunk? basically, what you need to do first is to position your subs outwards. baka ngayon, yung sub mo eh naka point in papasok ng car kaya andun ang bayo.
    kung wala pa din, tingin ko nasa settings na ng EQ and gains yan....
  8. #8
    Mataas na gain settings mo, so i don't think there's any problem with that. You go any higher than 1/2 (gain settings) baka mag overheat amp mo. It could be the design of the box, gaano ba kalaki? Can you specify the dimensions? baka masyadong maliit.
    ABC Box daw pre.
    ano yung ABC box?
    Signature
    Quote Originally Posted by boybi
    ano yung ABC box?
    Di po ba un ung mga calculated boxes???
    Oct 2003
    Outward facing na yung sub. I think the box size is fine though. Here's the pic.
    Di makita yung buong trunk sa pic e, basta 12" yung sub so dun nyo na lang i-scale yung size nung box. Also, can't tell you much about the depth of the box either, pero hindi sya maliit hehe
    Feb 2005
    ano yung ABC box?
    aperiodic bi-chamber.
    it's a ported box that has 2 chambers, one is 1/3 of the total volume, the other is 2/3's of the total volume and contains the sub(s). You tune it as one large enclosure with 2 ports. Using those port lengths you put one in the small side and one in the large side, and a 3rd identical one connecting the large and small chambers.
    ano ba differences ng mga boxes na yan? mine is a sealed one and hindi rin marinig sa labas ang bayo.
    Signature
    Feb 2005
    http://www.danmarx.org/audioinnovation/theories.html
    Dec 2003
    hmm one 12" sub is kinda 'bitin'...if 2 12" pwede pa
    Quote Originally Posted by BlueBimmer
    di naman siguro bro... i have used one 12" before, dinig na dinig sa labas eh. i think it would have to do with the amp setting.
    Dec 2003
    Quote Originally Posted by happy_gilmore
    hmm sa bagay..dapat pinalaki nalang ung box and 2 12" subs napasok instead of one..most of the time kasi mga naka 1 sub setup is for interior bass lang..bonus na ung malakas sa labas
    or 1 15"..
    Jan 2004
    Medyo OT lang bro, pero curious lang ako. Pag nakikinig ka ba ng sounds mo, nasa labas ka?
    Oct 2003
    Quote Originally Posted by the_wildthing
    Nope, sa loob . Don't get me wrong, I love the way it sounds when I'm driving. Siguro sanay lang ako makakita ng mga auto na dinig mo yung bayo pag dumadaan, and I'm just wondering why my system isn't doing that. Kung tweak lang naman ng settings or whatnot, e di pwede ko i-try. But kung talagang di kaya ng setup ko yun, ok lang. Sa loob naman yung pinaka importante.
    so ganun pala ABC box design. we dont use that kind of design kaya I dont understand what it is.
    Boybi pag sealed it is more tuned for SQ ang dating ng bass.
    so have you tried it sub facing forward?
bass stays inside
