Page 291 of 307 FirstFirst ... 191241281287288289290291292293294295301 ... LastLast
Results 2,901 to 2,910 of 3070
    Dec 2007
    #2901
    Good evening mga sir, I recently upgraded the stock speaker of my Mazda 3 to focal 165AS front and 165SC rear, tanong ko lang, na notice ko lang kasi minsan yung sound humihina and then lalakas, ano kaya ang problema??? I plan to go back to where I have it installed but I want to hear from you guys muna baka alam nyo, thanks!!!
    When you get back to your installer tell them to check the ground of the HU.
    #2902
    Check ALC settings, sir.
    Apr 2012
    #2903
    Quote Originally Posted by mda View Post
    You need an amp pag ganun but you'll need to confirm.
    the stock HU normally can power the speakers at decent volume without external amp. but yes, confirm niya muna sa installer baka lang may isyu sa connection.
    Oct 2007
    #2904
    Thanks for all that replied, I'll check with the installer
    Oct 2014
    #2905
    Guys,
    Planning to upgrade my vios speakers (front 2-Way Separate) to Pioneer TS-A1606C.
    Any recommendation on what yung match na amplifier? pasama na din sub.
    Prefer sana pioneers din pero if mas may okay mas better.
    Been using pioneer x595BT Headunit.
    Any recommended trusted shop sa South (Muntinlupa , Laguna)?
    Willing din pumunta sa banawe. Any trusted shop?
    Any shop na open ng Sunday morning para less traffic
    Thank you.
    #2906
    Recently got these as a gift and had them installed on the CRV. No idea if this is a good set but I just finished setting it up with its fancy DSP that auto-tunes everything with just a click of a button.
    Sound is noticeably better than the stock system with a soundstage at center of the dashboard and a richer sound with deeper bass and more pronounced highs.
    However, the vocals feel slightly overpowered by the instruments so I used the stock HU EQ to boost treble a bit to have more clarity with the vocals.
    Is this a decent set? Haven't upgraded any of my cars' audio systems prior to this.
    Follow up question - the sound stage is very nice when seated on the driver's side, but when on the front passenger seat it doesn't sound the same, although it still sounds good. When tuning, is the sound really just optimized for one spot?
    #2907
    ^ bro jut if youre willing to spend a bit for "labor". pa tune mo kay simplesound or mickeys.
    Oct 2014
    #2908
    Quote Originally Posted by rownyguzi View Post
    Guys,
    Thank you.
    Guys, okay na to. Got it set up by Jeff Tan last December. Went Full active with ‎TS-D1730C seps.
    Aug 2009
    #2909
    Yes the soundstage is optimized sa driver's side. You can retune it para yung sound is balanced between the driver and passenger seat but it won't be the same.
    Good package yan for some who's looking for a sound upgrade. The same set is being sold at 65k ata sa Ayala-owned Honda dealerships. Where did you have your tweeter pods fabricated? I think no tweeter provision yung 2.0S same as the 1.6V.
    #2910
    Quote Originally Posted by Sleepcare View Post
    Just ordered the tweeter housing of the 1.6S from Honda QC then had them installed along with the speakers.
audio set-up for beginners [continued]
