Results 2,801 to 2,810 of 3070
- Oct 2008
- 525
February 18th, 2018 04:44 PM #2801X595BT boss. Curious lang kasi ako ano yung readings nya sa time alignment.
- Feb 2018
- 1
February 20th, 2018 11:27 AM #2802mga Masters help lang po, meron po akong AVT ISW-1000 active subwoofer meron po syang output wire na blue w/ white stripe na "P Conn" nakalagay, question po saan ko po iyon ikakabit? thanks po mga masters.
tsikot ko ay vios 2015
February 20th, 2018 07:26 PM #2803
- Mar 2018
- 22
March 4th, 2018 02:09 PM #2804Hi good afternoon. I'm new with audio set up and would like to ask for your opinion as well
My ride is Ford Everest 2013 model. My audio now is the stock radio i got but since it is busted (gps not working, can't read Itouch, steering controls doesnt function sometimes) I've decided to get Growl audio as my headunit. I have bazooka type nakamichi sub and caido (not sure of the brand) for my speakers and tweeters in front.
Talked to the local shop and mentioned my plan to upgrade. He said 12k is on a budget meal that composed of Jbl sub (not sure with the model), box, amplifier (kinetic, not sure about the specs).
Given the budget, do you guys have some specific brand/model in which we can see as alternative?
Thanks in advance and will wait for your opinon. Have a nice weekend [emoji4]
- Feb 2017
- 141
March 4th, 2018 04:34 PM #2805Mga masters, ano feedback nyo sa gmd9601 mono amp ng pioneer? May naka gamit na ba sa inyo? Stock unit lang speakers ko at hu. Nilagyan ko lang ng sub na budget jbl kaso yung amp ko x12 medyo mainit sya feeling ko di kaya eh kaya balak ko palitan.
Sent from my SM-T705 using Tapatalk
March 5th, 2018 08:52 PM #2806
The Pioneer GMD9601 outputs 500/800/1200W and costs $280. If you're talking about price to power, it's sulit naman. Problem is: would you require that much power? Since from the looks of it, chances are you don't need it.
Your X12 will naturally be hot. As long as it isn't going into thermal protection, ganyan talaga yan. It's a Class AB amp after all. If you're looking for a mono amplifier, it's best to settle for something less pricey. Hindi mo kilangan ng mahal na mono amp as distortion is all but prevalent at the lower frequencies. Kahit PHP9000 Sound Magnus Class D amp is ok na.
What you'll generally be looking for is:
- Class D amp - efficiency is king
- Hopefully it goes down to 1 ohm load - it indicates how good the power supply of the amp
- Affordability - because everybody wants savings
March 6th, 2018 04:34 PM #2807
Hi everyone!
With a Morel Tempo Ultra, is it better to use a Helix G4 amp or Morel’s new amp MPS4.400?
And do you guys suggest having 2 amps (4 channel + mono amp) or just get a 5 channel amp (Helix G5) instead?
Thanks in advance!
March 6th, 2018 04:41 PM #2808
bro ask simplesound sa fb, afaik he installed the most g4 and g5s.[emoji848]
Sent from my SM-G935F using TapatalkLast edited by StockEngine; March 6th, 2018 at 04:45 PM.
- Oct 2008
- 525
March 10th, 2018 09:24 AM #2810My 5mo old X595BT suddenly wouldn't boot. It was working prior to parking then when I am about leave, it did not power on when I started the car. I thought there are busted fuse in my car but testing them yielded good results. I went back to the store and they pulled it out. Good thing I did not sell the stock HU and panels for my vios so I have asked the installer to install it back for the meantime. Hope it gets repaired / replaced soon as I can definitely hear the difference in sound quality.
Toyota's Land Cruiser 3�� Finally Gets a Hybrid Version with the 2�26 Model — The Most Powerful Yet...
2021 Toyota Land Cruiser LC300
