Results 2,781 to 2,790 of 3070
- Aug 2015
- 36
February 8th, 2018 03:52 PM #2781Good day friends.
So I already sold my 2015 Altis including all SQ equipment installed. I will be getting a Wildtrak and contemplating on the equipment to be installed. I still like how the AP RAM sounds. Jonz suggested the RAM 1.6. Coming from the RAM 2.6 I think this is a good pick as it would also fit well with the Wildtrak's tweeter stock location. Any other alternatives that are comparable or better than the APs for the seps which costs around 20k to 40k? I listen mostly to jazz, pop and a bit of R&Bs.
Would also like to hear for any suggestions on DSPs for integration. Hard to replace the Wildtrak's HU due to sync3 issues and connectivity with the truck's other systems. I have seen the HELIX P6 dsp + amplifier which costs 60k+. Thinking probably getting a 4ch amp + stand alone dsp but would appreciate other inputs.
I can go sub less. But Jonz mentioned the Ryan Audio underseat subs. Meron ba sa atin may naka gamit or nakarining na nito?
Thank you guys
February 8th, 2018 05:55 PM #2782
^ako gamit ko ngayon ryan audio na underseat subs. No complaints naman ako pero hindi ako audiophile kaya baka iba standards natin. What's good for me maybe crap for you [emoji3]
btw, who's jonz?
- Jan 2018
- 24
February 8th, 2018 06:13 PM #2783
February 8th, 2018 07:25 PM #2784
^ what's causing the amp to overheat? Could this happen to active underseat subs as well?
Sent from my ASUS_Z00AD using TapatalkLast edited by baludoy; February 8th, 2018 at 07:53 PM.
- Feb 2017
- 53
February 8th, 2018 08:10 PM #2785
- Jan 2018
- 24
February 8th, 2018 09:20 PM #2786
- Jan 2018
- 24
February 8th, 2018 09:34 PM #2787Set your gain on your amp and hu the right way for it not to clip. If you have a sub, use 40hz test tone to set your gain properly and Use 1khz for your component speakers
Adjust it seperately and with your bass boost off, subsonic filter off, your eq flat. There are a lot of youtube videos on this and you can download those test tone for free.
And remember: amplifier gain knob is not a volume knob.Last edited by Louie47; February 8th, 2018 at 09:38 PM. Reason: Additional info
- Aug 2015
- 36
February 8th, 2018 11:23 PM #2788
February 8th, 2018 11:57 PM #2789
- Oct 2008
- 525
February 9th, 2018 11:52 AM #2790There also test tones in Spotify. I am also interested in the Ryan Audio underseat subs but wonder how does it perform vs the JBL BassPro SL.
Regarding the JBL BassPro, I have inquired in one JBL store and available naman sa kanila kaso wala daw harness. Ano yun? Paano gagana yung underseat subs pag ganun? Lol.
It may be variable speed I think. It's slowly being used on cars that either don't have an ICE, or...
A/c
