Results 2,441 to 2,450 of 3070
- Mar 2013
- 6,160
June 25th, 2017 11:16 AM #2441Its along amang rodriguez avenue.
June 25th, 2017 12:39 PM #2442
- Apr 2017
- 45
- Jul 2004
- 241
June 30th, 2017 07:07 AM #2444Guys pa audition naman ng new focals. Dati kasi i find the tweeters ng focal medyo matalas and fatiguing. Some say na iba na daw ngayon. I plan to install a sound setup sa starex namin and i want to see kung ok na yung tweeters ng bagong focal ES165k / ES 165K2 / ES 165KX2. I plan to power them with Helix G5 (subs is JL 12w3v3) using a Helix DSP.2 (Head unit = Pioneer 8850)
Kung meron din sa inyo merong 10" in a sealed box, baka pwede din pa audition. I want to see kasi kung kaya na ng 10" sealed yung starex para mas maliit lang yung box.
Music pref ko is pop, jazz, 80s, disco and the like. Im not really into rock/trance/hard core music/etc
Salamat!
- Apr 2017
- 45
July 2nd, 2017 11:24 PM #2445
July 3rd, 2017 01:05 PM #2446
July 3rd, 2017 03:22 PM #2447
They're not effective for their cost.
As a previous thread: flashband users feedback
Just because it's cheap, doesn't mean it'll work well. I go write a 3 paragraph long explanation on why but many people won't like me delving into physics of mass and resonance.
- Oct 2012
- 196
- Jun 2017
- 4
July 3rd, 2017 08:40 PM #2449pwede ba to mga sir sa Isuzu Crosswind XUV (2003)? or kung may masuggest kayo mas ok or mas murang alternative. CHEER 7in Touch Screen HD Car DVD-player Stereo Radio Audio GPS
Memory Navigator | Lazada PH
TIA
July 4th, 2017 12:08 PM #2450
Noise dampening insulation basically comes down to two things: absorbing or blocking the sound, and reducing/eliminating the movement of parts which leads to vibration and rattling noises.
To tackle the latter..
You need to understand the three parts of sound deadeners..
1. mass to be dampened (sheet metal in a car)
2. constraining layer (butyl rubber)
3. reflection dampening layer (aluminum layer)
When the mass to be dampened (henceforth sheet metal) is vibrating, it will ring until the energy is either lost in heat, or radiated into the surrounding air as kinetic energy. Vibrations from the cars driving along the road, the air moving past the panels, from the engine just being turned on - all these can excite the atoms in the sheet metal and make it reverberate and we consider this movement as "noise". To negate it, we need to counter the ring with an equal but opposite force as best we can. Thus enters the sound deadening where the constraining layer (butyl) is set to bond with the reflecting dampening mass (aluminum) to the sheetmetal that will respond to a vibration with an opposite vibration -- canceling out the first vibration.
To do this, they use the first vibration impact to push the aluminum layer at a delay that coincides with its distance from the sheet metal. this first impact causes the aluminum to vibrate out of phase with the sheet metal, hopefully causing both of their vibrations to stop dead in their tracks - or close to it. This is why the butyl viscosity and its thickness are very important to get the aluminum layer to vibrate at the right phase-time to the sheet metal.
In reality tho, the vast majority of the dampening is less on the aluminum layer but more on the forces the butyl creates. This is why I don't mind generic OEM butyls with no aluminum layers on it.
But that's the vibration aspect and more geared towards car audio...
If we look at the former..
A piece of paper won't block off sound well. But a huge slab of concrete will. You basically need mass to absorb sounds.
Now, don't worry, there's actually a car running in the Philippines that has concrete poured inside it as a cost-effective way to reduce vibrations and noise. But that car competes in worldwide decibel competitions as any vibration (or out of phase sounds) reduces your score drastically. For one, it has enough decibels to kill a person inside
Yikes that(tesla) is even worse although upon some additional reading i'm not even sure our Seagull...
BYD Seagull
