Page 74 of 154 FirstFirst ... 246470717273747576777884124 ... LastLast
Results 1,461 to 1,480 of 3070
    Aug 2012
    #1461
    Feb 2011
    #1462
    Quote Originally Posted by chito2011 View Post
    paps, what are separates speakers, eto ba yung component type? Thanks
    yung hiwalay po yung tweeter and midbass/midrange drivers.
    Feb 2011
    #1463
    Quote Originally Posted by hinlog View Post
    hi sir,
    May I know, why do you recommend to go for Separates instead of 6x9? I went to a nearby shop, basically they quoted me the same price 4500 for either 6x9pioneer 3way speakers kor the front door or kicker separates (?). Target unit is navara, no approved budget to replace HU yet :-). Thanks.
    Separates can be mounted infront, and we would like to stage to be there not on the back. Separates too tend to sound clearer because each driver can focus on certain band of frequencies.
    #1464
    Quote Originally Posted by sientobente View Post
    Just an update...
    I went to the audio shop this morning and they were kind enough to test install one side with dsl entry level separates while pioneer 6x9 at the other side. In the end I opted for the former, they're both okay, gaya nga ng sinabi nila, you decide which you think suits you best. Total damage, 5500 net of discount. Thanks to all!!
    Aug 2010
    #1465
    6x9 speakers are basically coaxial designs on a 6x9 size format. Separates do not sound better because it's "separate".
    In fact, if you can mount 6x9 speakers on fat A-pillars like one on a FJ Cruiser, that would be awesome. You get a point-source and phase-correct system right off the bat.
    Sep 2011
    #1466
    yung coaxial po ba hindi? thanks ulit, sorry sa maraming katanungan he he he
    Sep 2011
    #1467
    Quote Originally Posted by jhnkvn View Post
    correct me if im wrong, paps... opinion ko lang... palagay ko naman ang set up sa home stereo ay kaparis lang din ng sa car stereo, di po ba?
    so I think para tumunog ng maganda ang separates speakers... you need an equalizer, and a good amplifier... but actually, im not so sure abt this... theory ko lang...
    Aug 2012
    #1468
    Not just for separates but for coaxial speakers rin, equalizer is needed to properly tune your sound setup to your taste.
    Most HU have built-in digital equalizer, with some more advance than others. If you are an audio enthusiast, then what you want is separate L and R channel equalizer controls. The more bands, the better.
    Amplifier is optional only.
    Feb 2011
    #1469
    The ideal scenario sir, if it is flat, it should sound correct, without any coloration. This is why most home audio amps, tend to forego tone controls already. Home audio will still have a big advantage over car audio mainly because of the car's cabin and the limitation of the driver's enclosure. On coaxial drivers, I am not much of a fan of those. Even in home audio applications like the KEF Q series or those Full-range drivers like Audio Nirvana. I find them cloudy.
    Sep 2011
    #1470
    Quote Originally Posted by red_one View Post
    So ano mai a advise nyo sa akin mga paps? what brand can you recommend me, affinity, polk audio, focal? oops mahal yata yung last kong nabanggit he he he. if my 5k ako, 2 front speakers muna.. kahit stock lang ng Toyota ang HU.. ang type kong music ay pareho kame siguro ni sientobente, medyo mahilig ako sa tunog acoustic (or more of a strings sounds ang kumakalma sa akin he he he).
    Feb 2011
    #1471
    I think Auditor Audio sir should fit your budget, it is also developed by Focal. It has very similar qualities where it does have that lively sound signature Focal has.
    Aug 2010
    #1472
    Buy anything within your budget. Most of them roughly sounds the same lang naman. Sound differentiation starts quite late once materials start dictating the sound signature.
    My vote? You go for local - Targa, Ryan Audio, Firland Audio. Or you can go international - JBL, Pioneer, etc.
    Sep 2011
    #1473
    thank you mga paps
    Feb 2011
    #1474
    I forgot, there is a cheaper sep that sounds lively too, the Audio System MX165. I think this only cost around 3.5k. Auditioned one from my installer mounted on sail pods in a mirage then they added deadening. It has good potential. The amp that was powering it was a JBL A604.
    Jun 2013
    #1475
    thanks sa reply mga sir,
    another question po (pasensya sa kulit)
    saan po pwede i-tap yung remote-turn-on wire ng amplifier (blue color) kung walang remote wire po yung head unit?
    Dec 2007
    #1476
    Sa accessory wire po found in the ignition switch. Usually color yellow po yun wire na iyan. I suggest letting a knowledgeable car electrician car audio shop do it for you. Pwede din mag lagay nang toggle switch in between the positive wire where the radio gets its power. Problem lang dito medyo hassle kase you now have two switches in order to turn on your radio.
    Anyway, i'm sure kayang kayang na nang mga car audio shops gawan nang paraan iyan.
    Dec 2007
    #1477
    double post
    #1478
    Question po mga experts. I wanted to upgrade my stock speakers and have 2 options considering that I do not intend to install amplifier (head-unit lang po direkta ang kabit ng speakers. Which would be a better option: 1- JBL seps in front, JBL coax rear and an underseat active subwoofer OR 2- Morel Maximo seps in front and Morel Maximo coax for the rear. Both options are somehow on the same price range kasi. I like a clean install kasi kaya a protruding subwoofer is out of the option. I just like to achieve a cleaner sound with nice lows vs the stock speakers. By the way, I am already using an aftermarket HU (Kenwood 2-din)
    Aug 2010
    #1479
    Quote Originally Posted by ralphs View Post
    #1. The addition of an underseat active subwoofer is a "leap" in tonality.
    Jun 2013
    #1480
    sir what do you mean by "Leap in Tonality?
    sorry po medyo slow ako.. :D
audio set-up for beginners [continued]
