Page 65 of 154 FirstFirst ... 155561626364656667686975115 ... LastLast
Results 1,281 to 1,300 of 3070
    Sep 2006
    #1281
    Planning to upgrade the sound system of a 2014 altis 1.6v... thinking of getting focal seps (access 165 2 way), an amp, sound deadening for the front doors.. thinking of recycling my old boston rally sub, but would be needing a new box.
    Have a budget of around 30-35k for phase1.. Could you recommend an amp, and would this sound good using the stock hu...
    Toying with changing hu to a pioneer 5650 dvd player but nanghihinayang ako since bago pa yung hu... baka phase 2 na lang
    Thinking of getting a jbl 5 chnl amp but installers i called are saying mag 4 way nalang. 3 installers recommended different brands, one yung gladden for 9.6k, another yung rf punch for 12k. The 3rd recommended a mosconi for less than 12k but suggested i get the focal flax 165 for 15k, pero palitan ko daw muna yung hu.
    Not familiar with the gladen... any feedback on these?
    Am confused... appreciate opinion kung
    A. Get the focal flax and pioneer hu 5650 plus sound deadening.. (eventually get the amp plus reuse the sub)
    B. Get the focal access plus ??? Amp, sound deadening and reuse thesub... ( and what amp to get)
    Appreciate your thoughts. My current ride is a fd with infinity seps, jbl 4 chnl amp (gto na orange) and the boston rally sub in an oversized sealed box.
    Tnx
    Sent from my ASUS Transformer Pad TF700T using Tapatalk
    Feb 2011
    #1282
    I would suggest a step by step upgrade so you would enjoy the difference for every change in your system. Like go with the Seps first and deadening for Phase 1.(Focal seps are very easy to power with an HU). Phase 2 add an amp and so on. If you are not keen on changing the HU, an alternative is to get an external processor to keep the OEM look. I am doing the same on my car.(Progress found in Kotseaudioclub )
    Regarding the brands, gladen bought the mosconi/audio system brands wherein he rebrands their amps. mosconi, most of the time matches very well with focal, but there are some certain pairings that does not sound well. Ask your installer which one he recommends because most of the time, that's the pairing he has experience with and has quite some success with it.
    On your choices, I choose A. I experienced Flax. It's very different from the previous Focals of yore but retaining the qualities we love on that brand but probably hold off the HU upgrade first as I stated in the first paragraph.
    By the way, I also own the current-gen 1.6 Altis. IMO, The stock system does not sound that bad. I would actually rate it a lot better than my CRV's and Montero Sport. Try to break it in first to hear it improve.
    Sep 2011
    #1283
    Hi mga sirs, I will be getting the Vios j 1.3 m/t, I know that this model's audio isn't that good, 2 lang speakers, any suggestions on how can I improve it? Kahit pa unti unti muna... How about kung upgrade ko muna ang speakers?
    Feb 2011
    #1284
    That will work sir. But installation is very important. May kilala ako, who upgraded his stock speakers, and since it was bit larger than stock, and no mounting adjustments were made, it sounded worse.
    For speakers, choose high sensitivity ones so your HU can power it easily.
    Sent from my GT-N7100 using Tsikot Car Forums mobile app
    Sep 2011
    #1285
    [QUOTE=sientobente;2414951]That will work sir. But installation is very important. May kilala ako, who upgraded his stock speakers, and since it was bit larger than stock, and no mounting adjustments were made, it sounded worse.
    May ma re recommend ka ba sir na brand? Meron akong luma, audio dynamics (familiar ka po dun?), balak ko sana palitan yung stock speakers ng vios pag nakuha ko na, tapos palagyan ko pa 2 speakers sa hulihan, ano kaya babagay dun
    My concern now is, will the stock hu of the Vios accommodates 4 speakers he he he
    #1286
    hi peeps,
    i want to improve stock audio setup of my navara 2010 but i want it to be done in phases. should i begin looking for HU or start with speakers muna? any good shop that you can recommend within binan? tia
    Posted via Tsikot Mobile App
    Feb 2011
    #1287
    [QUOTE=chito2011;2414954]
    Quote Originally Posted by sientobente View Post
    Regarding the brand, depende po sir sa budget and also your preferred sonic character. Most HUs should be able to accomodate 4 channels, but if I were you, forego the plan of installing rear speakers coz the stage should be infront to add realism. Parang when someone sings, the voice comes from the front and not around the cabin which makes it confusing.
    Not familiar din sir on the audio dynamics brand, and syempre if you are getting a new car, get a new set of speakers that your brand new car deserves
    Feb 2011
    #1288
    Quote Originally Posted by hinlog View Post
    hi peeps,
    Each has its own advantages. What do you find lacking on your system now? A good installer I know fom the South is Bluprint/Musico from Paranaque.
    I am also building my latest project in phases. You can see it at www.kotseaudioclub.com
    Sep 2011
    #1289
    [quote=sientobente;2414992]
    Quote Originally Posted by chito2011 View Post
    ay sir, sorry bigla ako na confuse sa advise mo, gusto ko lang I clarify, the vios e (yung sumunod na model ng j) has 4 speakers, di ba mas maganda at malakas ang tunog na apat kesa sa 2 lang? so you mean, ok lang yung 2 sa front at wag ko na dagdagan ng 2 pa gaya ng vios e model? TIA
    Sep 2011
    #1290
    [QUOTE=sientobente;2414992]
    Sep 2011
    #1291
    hi peeps,
    may DB audio ako nakikita sa binan ah, along the highway lang sya, left side sya going to santa rosa. pero di ko sure kung ok
    Aug 2010
    #1292
    Quote Originally Posted by mortis View Post
    Tnx
    In your case, no need to go for the 5-channel. This is because you already have an existing 4-channel amplifier so just throw in another 4-channel and you're good to go. 8-channels of amplification is more than enough for most people (even hardcore enthusiasts).
    Mosconi positions themselves higher than Gladen but essentially same company lang yan. RF products are historically built like tanks and that's the reason why installers recommend them.
    I'll go for A if you plan on upgrading in the future and B if you plan on stopping there na.
    The first two things you should always do is: (1) change to aftermarket speakers, (2) deaden your front doors. Do these and I'll guarantee you better sound quality off the bat.
    Since most of us drive our own cars, upgrade mo muna yun harap and stock muna yun likod.
    hi peeps,
    Hmm.. depends. Usually I'll recommend a head unit change if hindi maganda ang head unit mo. However, most modern head units are well-built naman so my vote will go for a speaker upgrade muna.
    Err.. not much familiar sa Binan (hell, taga North ako so expected..) DB Audio is formerly KID Audio. Mixed reviews sila AFAIK since there's good and bad reviews. However, madami nagsasabi they charge a hefty price. I've also heard a couple of reviews of BP-1 Car Accessories.. but I haven't heard reviews on whether it's a plus or negative. Autobisyo near Southwoods, on the otherhand, is considered expensive by many for their work. Hope that helps.
    #1293
    hi sientobente,
    I observed that it sounds better if music is coming from CD but not when im listening music from radio. I meant, parang hindi hindi ginagamet ung ibang speakers or ganun lang ba talaga? muli, salamat.
    Feb 2011
    #1294
    [QUOTE=chito2011;2415023]
    Ganito po sir, having 4 speakers won't necessarily make it louder. Just imagine speakers as flashlights. 4 na flashlight and it has its own coverage in the cabin. The reason why it won't go louder is because when you crank the volume, distortion will easily come up. Much better pa sir to keep a good front speaker and then use an amplifier to get the loudness and clarity you desire.
    Feb 2011
    #1295
    hi sientobente,
    Oh if the source is really from an FM radio, it will really turn out bad. Garbage-in, Garbage out principle po. Kahit gaano kaganda yung setup, when I listen to Mo Twister on the radio, he still sounds like crap. And if the source is also the radio/fm, your headunit might have set it on stereo mode rather than multi-channel, maybe there is a setting somewhere that can change that.
    #1296
    Natawa ako dun ah. :-)
    Sep 2011
    #1297
    [quote=sientobente;2415285]
    if you're sitting behind, will you hear the music if there's just 2 speakers in front? I don't know kung nagkakaintindihan tayo. but never mind, di pa naman ako magpapakabit, naisip ko unahin ko muna ang keyless entry with alarm kesa sa upgrade ng speakers he he he
    Sep 2011
    #1298
    Jeff from ACA give me a quote to upgrade my front speakers and install rear speakers + deadening of all doors. I have Innova J, no stock rear speakers and will go for SQ setup. No plans on replacing my HU yet, wala pang pera.
    Feb 2011
    #1299
    [quote=chito2011;2415421]
    To simplify my answer sir, yes. Even with just 2 speakers it is enough to fill out an entire cabin, even if that is as large as an SUV. if you would like a demo, kotseaudioclub holds its car audition nights every friday at HID Burger Marcos Highway. Everyone is welcome to join and experience car audio and learn from our gurus. It's for free. I'll also be there on one of its meets. My suv(the one in my avatar) currently has only 2 speakers(no subs yet) and I think that will best describe what I was talking about when you hear it
    Oct 2014
    #1300
    hi Forum peeps...
    good day to all...
    am so new at this so please bear with me.
    i wanted to find out, what's the current decent sound set-up i can come up, with not so much of a budget killer.
    can any expert here lend a hand, and let me know what are the things i need to have/purchase and install in my car (corolla 2000).
    thanks to all...
    Cool_Charlz
audio set-up for beginners [continued]
