Results 1,241 to 1,250 of 3070
September 18th, 2014 12:17 PM #1241
Uhhm boss, when connecting a 4 channel amp to a pair of front speakers, make sure to connect the speakers wires to channels 1 & 2 of the 4 channels amp. This is because in general the front signals of a 4 channel amp is located on channels 1 & 2, while the rear signal is on channels 3 & 4. Para lang po tama ang install ninyo.
Ang tanong ngayon is where did you set the filters of the amplifier on channels 1&2 and 3&4?
September 18th, 2014 12:24 PM #1242
- May 2014
- 10
September 18th, 2014 11:35 PM #1243
September 19th, 2014 12:00 AM #1244
Sir jhnkvn, I know familiar ka sa mga JBL. I was able to download 2types of GTO609 pdf spec sheets. When I was reading both spec sheet and compare it to the pdf owner’s manual may pinagkaiba pala (RMS and frequency). I want to ask which is which. Maybe new and old model, but how would a newbie know which is the old and the newer model?
Here is the screenshot:
- Jun 2014
- 64
September 19th, 2014 12:38 PM #1246
mga paps...patulong...i have HSK 163 (3-way), amp would be LRx 5.1k and I'm planning to have it semi-active. But not the usual 3-way semi-active wherein TW+ Midrange for amp A-channel in A-pillar, and Midbass for amp B-channel. Question is:
would it be advisable na ang TW for A-channel, and midrange + midbass for B-channel? Midbass would be in stock location(door molding), and midrange would be in kick panel, while the tweeters would be in a-pillar?..
doing so will make the soundstage larger and for additional depth? and to avoid that "in your face" sound?...
what would i be facing in this kind of setup?
TIA
- Jun 2010
- 72
September 19th, 2014 02:35 PM #1247
- Mar 2013
- 6,160
September 19th, 2014 09:22 PM #1248Can anyone recommend a decent slim type subwoofer that will fit under the seats of the new honda jazz GK?
Posted via Tsikot Mobile App
September 20th, 2014 03:46 AM #1249
if I'm not mistaken, there is enough space below the rear seat of the Jazz. You can fit a custom sub there. Jonz of Simple Sound creates one. This is better than any over-the-counter sub you can buy from stores.
https://www.facebook.com/pages/Simpl...08193979267863
Here's his digits:
+639176885170 landline 7926695
- Aug 2014
- 212
September 20th, 2014 10:25 AM #1250Hi what's the usual service fee for taking out the 4 stock speakers and installing new ones? One is asking 500 per speaker. Do you know of any shop in Pasig Ortigas area that does this competently (correct and clean installation)? Thanks for your reply.
i confess, my seagull review is from internet literature. that so-called aircon issue is a...
BYD Seagull
