Results 1 to 20 of 3070
Threaded View
    Apr 2012
    Quote Originally Posted by simonzaide View Post
    Hi sirs
    I would like to get inputs for a sound set up like this
    Stock head unit
    - sound processor
    - 2 way fronts
    - coaxial rear
    - 2x 8 inch subs
    - amp
    Would like to get inputs on brand and model
    Would like a very stock looking sound system as much as possible
    Budget is open naman
    since your budget is open, there are so many brands to choose from. starting from the low budget to the high-end ones depending on the type of system you prefer like SQ or LnC.
    as a headstart, consult a reputable audio shop and installer and lay down your preference. most likely they can hook you up to audition some of the installs they had. shops like mickeys, musico, jc car, mach2,phataudio, simplesounds, projectai etc. are some of the well known shops that you can check upon.
    - processors like audison bit ten/one, jbl ms8, mosconi 6 to 8, alpine pxa h800 etc. are some brands you can check
    - 2-way fronts, focal, dls, seas, micro-precision, bewith, morel, audison, hertz...etc. just too many models to choose from ;)
    - coaxial rear, you can put any coaxial speaker but its seldom use in a 2-way system
    - 8" subs, just like the front speakers, there are too many brands and models to choose from ;)
    - amp, depending on the power requirement of your system. there are mono, 2/3/4/5/6 channels available, 4ch and mono combi are common, 5ch are getting popular as well.
    check out kotse audio club (KAC), there are plenty of builds posted there you can refer to.
audio set-up for beginners [continued]
