Results 1,131 to 1,140 of 3070
- Jul 2014
- 1
July 29th, 2014 06:26 PM #1131Hi sir jhnkvn!
Sir i am newbie po, can you give me an advise po on a simple sound setup pero quality sound na po pero budget wise lang sya? I have a chevy spark po 2nd hand ko lang nkuha tpos pinalitan ung hu ng promac n analog. Im a little O.C sa sound kasi mahilig ako sa music, more on rock din.. I will really appreciate your advise po. I dont have technical backgroud po kasi sa car audio tech but i am trying to educate myself po. =) please help me po =)
July 30th, 2014 02:18 AM #1132
August 3rd, 2014 06:34 AM #1133
im downsizing/downgrading my setup
so im selling my current gears
fp 1.800
fp 4.75
33v2
morel tempo 6
how much do you think i can sell this?..not keen to sell separately
im leaning towards the 5 channel fpp5300 plus 8" p21v2, access 165
Posted via Tsikot Mobile AppLast edited by ozcity; August 3rd, 2014 at 06:41 AM.
August 3rd, 2014 10:50 AM #1134
Hi mga sir, tanong ko lang kasi may sub ako na pang under seat. May build in amp na pero pag nakataas ang volume, basag na ang tunog. Pwede ko bang lagyan ng separate na amp para maging buo ang tunog ng sub. Adventure po ang rides ko.
August 3rd, 2014 06:07 PM #1135
Need a referral to a shop in banawe that can properly tune the set-up of my ride. Current set up of my montero
Stock head unit with RCA out for 4 channels plus sub
JBL MS 8
JL audio 6 channel amplifier
DLS reference speakers front separates and rear co-ax
Pioneer center speaker
Kicker monosub 12inch
Note: center speaker connected directly to the MS8
Having difficulty getting the right sound. Appreciate the referral , thanks in advance
August 4th, 2014 05:45 PM #1136
Your best bet is to search at KAC's ICE section for references and price them similarly. I'm not too sure if that's of a downgrade, in my opinion, seems like a same-level "refresh". If the gears are still working fine, I suggest you still use them.
No. Self-powered subwoofers have their own internal amplifiers that moves them.
Uh oh. Well.. the thing with the MS8 is that it isn't really as plug-and-play as it looks to be. However, its auto-tune function is incredible - it really saves time needed to get at least 80% of your tuning potential.
There is no shop in Banawe that can tune your MS8.
For that, you will have to go for the bigger ones like JC Car Audio in San Juan, Musico Mobile Audio in Paranaque, and Mickeys in Pasig.
There are really just two tips I can give to you:
1. Make sure wirings are all correct and of correct polarity.
- The MS8 setup is pretty straightforward - you just need the correct installation you won't screw it up.
2. Do the tuning dead at night - no noise should be heard when the sweeps are in progress.
Again, contact me. Truthfully, I've only heard two JBL MS8 setups that sounded correctly.
August 5th, 2014 07:42 PM #1137
Thanks for the tips. Managed to sneak a few moments from the office and did a re-calibration of the system at the basement parking. Got the 80% potential of the unit and will fine tune at home this weekend.
- Jul 2013
- 54
August 7th, 2014 11:56 AM #1138Hi mga sirs, firstoff, andami kong natutunan dito sa forums, maraming salamat mga sirs! I have a vios 2013 with ryan audio setups (seps, p604 amps, subs) and I'd like to upgrade my HU. Based on previous posts maganda daw yung pioneer (avh-x2650bt) (about 12-14.5k according to some sellers and olx);
Question lang sirs, mayroon ba na shop na nagbebenta na BDO 0% installment?TIA!
- May 2014
- 10
August 8th, 2014 12:28 AM #1140
Pwede po bang ma-acchieve yung sound set up na para kang nakikinig sa I-phone or ipad? yung buong buo ang tunog and tamang tama lang ang base.
Ang stock unit ko is AVT and sa mga nabasa ko, kailangan palitan yung HU to get a nice sound set up.
Ang worry ko lang is mawawala yung built-in GPS ko which I really enjoy.
Ano po bang HU ang available na hindi masyadong mahal and me built-in GPS and at the same time will give you a good sound output like Pioneer.
Sent from my iPod
Sa Everest/Ranger parang hindi naman issue yan afaik. Yung EGR pa na nalulusaw ang plastic sa mga...
BYD Philippines
