Results 1,061 to 1,070 of 3070
- Jun 2014
- 5
June 10th, 2014 02:40 PM #1061Hi sir jhnkvn/mga gurus,
I'm planning to upgrade my stock system to SQ setup. My budget is between 50-60k lahat na po.
Ano po ba ang mga components ng isang SQ system?
Ano pong marecommend nyo na best components na pasok sa budget ko?
Last po, san maganda magpainstall?
Thanks po in advance
June 10th, 2014 08:52 PM #1062
- Sep 2010
- 8
June 10th, 2014 08:58 PM #1063Mga Sirs, pag naginstall ako ng separates sa front, mag rerewire ba ako ng direct sa hu or gagamitin ko yung stock wiring ng mid speaker at tweeter na stock? Hindi ba redundant kung ikakabit ko pa yung crossover ng bagong separates? Thanks
June 10th, 2014 09:51 PM #1064
^^tap lang sa original wiring. Kailangan yung passive crossover Lalo sa tweeter para hindi pumasok low frequency sound.
- Sep 2010
- 8
- Jun 2014
- 5
June 11th, 2014 08:09 AM #1066
June 19th, 2014 10:03 PM #1067
Components of a SQ system will be:
1. DSP capable head unit and/or a DSP processor
2. Speakers
3. Amplifier(s)
4. Wirings and enclosures (for the subwoofer)
I usually advice installations depending on your general area. For example, if you're at the North.. it might not be a good idea to advice an installer all the way in Paranaque for example.
At 50-60k, I will advice a good head unit (16k), entry-mid range speakers (15k), amplifier (10-15k), a cheap sub and enclosure tpos the rest for wirings and install.
The most important of these components is the head unit and/or a processor.
- Jun 2014
- 5
June 22nd, 2014 10:18 AM #1068
- Jul 2008
- 10
June 23rd, 2014 10:33 AM #1069My current car audio config:
- Kenwood DPX-U5130BT Head Unit
- Kenwood X700-5 Amp
- Polk DB6501 front doors
- Polk DB651 rear doors
- Polk MM1040 sub
I also still have a Kenwood M845 4-channel amp that is currently not being used (was replaced by the X700).
Curious about 3-way active setup and looking at acquiring the Pioneer DEH-80PRS.
Thinking of reconfiguring things as follows:
- Kenwood M845 as amp with Channel A for mid/mid-bass (*60W RMS 4ohm) to drive DB651 coaxial and Channel B for tweeter (*60W RMS 4ohm) to drive DB6501 tweeter. Will not be using the included passive crossover module.
- RCA splitters to daisy chain mid head unit RCA out to both M845 (channel A) and X700 amp (channel a & b).
- Bridge channel A and B of X700 amp (*100W RMS 4ohm) to drive DB6501 woofer
Not looking to acquire any new equipment except possibly the DEH-80PRS.
Any suggestions or comments (good or bad) about what I am thinking of doing?
Thank you!
June 23rd, 2014 03:28 PM #1070
If you will go active 2way + sub with the Pioneer DEH-80PRS then all you need is your current 5 channel amp. Disregard na po yun rear speakers niyo. Channels 1&2 for the tweeter, 3&4 for the midbass and mono channel for the subs. When you go active all the signals from the tweeters and mids transfers to the front. For short wala ka nang rear signal.
Edsa is about 24kms long. So, 15b / 24 is approx 625m per km?
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
