Results 691 to 700 of 3070
August 16th, 2013 10:13 AM #691
heard good feedback about lightning lab...mura na okay naman daw performance...some say comparable pa nga daw sa mga branded speakers...based lang to sa personal experience ng kaibigan/kakilala at nababasa ko ha...i havent tried their products but would want to try it as well...
Other brands you might want to consider are entry level of jbl, ryan audio, kicker, powerbass, or DD ka ulit! actually maraming choices...
- Apr 2005
- 132
August 24th, 2013 10:45 AM #692Guys I need your inputs...I was thinking of installing a boom box (active) sa Innova ko. Maybe one 4 channel amp to power the seperates. Crossover? TIA for your inputs.
August 30th, 2013 10:43 AM #693
mga sir, ask ko lang kung advisable ba na gumamit ng "active subwoofer" in replacement sa mga raw na subwoofer na need pa ng amp? thanks po
August 30th, 2013 04:56 PM #694
^^^Sir, what would be your reason for considering active subwoofer? For SQ or SPL use po? For what vehicle?
August 31st, 2013 10:53 AM #695
Whether it's active or passive has not much impact on the performance of a subwoofer. The difference between the two is that passive ones are highly customizable wherein active configuration subwoofers are like all-in-ones. It's like computers, the passive types are the ones you buy parts in Gilmore while you construct them spec-by-spec while the other is much like buying that shiny new Alienware you saw at the store outright.
Most car subwoofers are of the passive variety. This is because it's up to the installers to choose the best type of box and driver that would suit the owner's demand and taste. For example, sometimes space is an issue so an installer has to find a way to fit a >1.0 cf box inside the car.
Most home subwoofers, on the otherhand, are active. The simple ones simply consists of signal plugs (subwoofer RCAs for sub-level signals), a filter, and a AC power supply. The more expensive ones have a lot of features such as subwoofer parametric EQ, level control, phase adjustment, etc. In more cases than not, home subwoofers are quite expensive because of their extreme box engineering (like I said, the box determines the performance) which can be in the form of additional bracing, thicker panels, a more rigid type of wood, etc. which is why some people pay more than Php 200,000 for a JL Fanthom subwoofer while the less affluent settles for Php 100,000 Velodynes.
In a car environment, first know your needs.. then you construct a box according to that need. Afterwards, you worry about which driver to throw in the box. That's how experienced people do it NOT the opposite way which most people do (select subwoofer -> construct box -> done).
P.S. Most car active subwoofers simply... suck.
September 1st, 2013 02:13 PM #697
September 2nd, 2013 04:04 PM #699
Basta hwag lang magexpect ng sobra
...try to audition/demo it first para you have an idea...
Mga sir, ako din my question...i have a v12 F710 na nakatago na...nagamit ko sya ng mga 1 to 2 years...may problema lang ako sa rca input nya for channel 3 and 4...for some reason nabasag yung plastic part ng rca...pagawa ko pa kaya para magamit or mabenta? may alam ba kayo na pwedeng pagawaan kung worth it ipagawa? Thanks!
- Jun 2013
- 7
September 2nd, 2013 11:17 PM #700goodeve tsikoters.. newbie here. my ride is a 2003 crosswind xuv, i would like to change the rear speakers, i am still using the original oem speaker at the moment but i am not satisfied with its bass its lacking the thump that i am looking for. Can you suggest a good 6.5inch speakers with a good thumping bass? i am not planning to put a sub because i need the space. Anyway, i changed the stock front speaker with a sony xplod XS-GTF1027 4inch 2 way speaker. I am thinking of getting sony xplod or pioneer 6.5 for the rear. i just dont know what to get, my initial budget is 5k. By the way my HU is a pioneer deh-1550ub.
follow-up questions.
1. what kind of speaker should i use on the rear considering that i am looking for that boom-boom factor without using a sub? coaxial, midrange, component, 1 way, 2way, 3 way etc??
2. is my front speaker sony xplod XS-GTF1027 enough or should i change it?
Yikes that(tesla) is even worse although upon some additional reading i'm not even sure our Seagull...
BYD Seagull
