There are advantages and disadvantages of coaxial and separates. But generally speaking, if you can get separates up your frontstage, I'll prefer it over coaxials. Since the tweeter is often placed in the dash (or sail panel), the main benefit of separates is that of a higher soundstage. In other words, you hear the music ear-level rather than hearing them from your feet and this is generally desirable
This does not mean that coaxials are inferior. Heck, if I could fit a coaxial on my A-pillars I'd be happy to do so. Coaxials have the advantage of being close to the ideal loudspeaker design also called point source where the drivers are near to each other and thus are easier to tune (based on the time and distance it takes for the sound to reach the ears). But oftentimes, having a coaxial in the dash is unfeasible due to it's size problems ;)
Wala akong experience with DLS Performance separates. But knowing the brand, they should be good naman. Put them in stock speaker locations and get separates at the front pare then coaxials at the back. Even if you have them head unit powered, they should still be significantly better than the stock paper cones. Kilangan ba ng amplifier? I would highly recommend it para masmabusog yun speaker
