the best head unit sir is what fit your budget there, if you can go with alpine, were go ahead, it was the best for car audio like the alpine 9887, it's unique ability is the 24bit DAC, digital to analog converter which means from your song converted to mp3 format sound, if you play it to that kind of head unit, it will play like a cd format file or nearly to flack or wav file.. about naman po dun sa sub nyo, the rating 1200watts is its rated peak power, so just ignore these numbers, actually it's just around 300watts rms. Mono amp(like class D amplifiers) po is a single channel amp that only produce low pass frequency, good to a known subwoofer like you have and very efficient in power source, marami na ngayun ng ganung klasing amp na mura lang like our new lightning lab amp rated 600watts * 1ohm stable for around 5k in prices, your existing amplifier is a 4 channel amp normally in class ab switching, so limited on filtering such low frequency, sorry, but V-12 amps always isn't good in that way, it's rated power you said 2500 watts max is its peak combined power, mostly, they are around 80watts rms by 4 * 4 ohms, their just producing more on flat frequency responces and power so you need a good head unit or a crossover to do the work in fine tuning your system.
