Results 191 to 200 of 3070
- Sep 2004
- 340
May 2nd, 2011 09:18 AM #191may nabili ako 2nd hand na NBN subwoofer kaso walang kasama na wires. eto yung spec ng sub based sa website ng NBN.
NA-1028APR
10' sub-woofer
Frequency Response:30Hz-4KHz
RMS Power Range: 150W
Peak Power Handling: 500W
Impedance: 4 ohm
ano kaya ang minimum fuse rating para dito at kung anong gage ng wire ang dapat ko gamitin. pwede na ba ang 15AMPS at 14gage na wire. thanks!
- Sep 2004
- 340
- Apr 2011
- 7
May 8th, 2011 11:41 PM #193ako po ay newbie lang at may konting budget..
wala ako alam sa sounds pero gusto ko sana mag pa quote sa inyo mga masters within a budget of 20 - 25k..
thanks..
- Apr 2011
- 17
May 22nd, 2011 06:20 PM #194Hi! I have a problem with our honda civic. May maingay sa likod ng kotse namin. Sa speakers ata. Pag nilalapit ko yung tenga ko sa may speakers naririnig ko yung malakas na tunog... parang latang kinakaladkad... I have the feeling that I need to replace the speakers already? Do you guys know where can I buy budget car speakers... mga 4-5k lang budget ko eh. hehehe! Thanks in advance.
- Apr 2011
- 17
May 23rd, 2011 10:17 AM #195and by the way, hindi naman ako naghahanap ng sobrang gandang speakers. gusto ko lang mawala yung sound na maingay. thanks again.
May 23rd, 2011 11:04 AM #196
Depends if you have an existing headunit (HU) or not. Can't really quote one since shops show their SRP and you can haggle down there.
Go check Banawe. Madami doon gumagawa ng mga audio "packages"
Banawe is still the mecca of car modders. 4-5k? Firland, Dominations, maybe the entry-level Morels with konting hundreds more. Since stock sound systems shouldn't have that sound (and I doubt it's just system noise) maybe you should first consult with your auto electrician. Baka mamaya frayed wire or something.
- Apr 2011
- 14
May 23rd, 2011 07:53 PM #197Good day sirs! Need help and your expert opinion.
I want to setup my montero glv with stock head unit.
my budget is around 15k to 20k
Habol ko lang is sound quality. Hope you can give me suggestions as to what kind and specs of speaker I need to buy or Saan ako pwede Pumunta for my beginner set up .
Medyo excited na ko magkaroon ng good quality sound . Sarap kasi basahin mga audio setup thread dito kaya ako naenganyo.
salamat po sa advise.
More power!
May 23rd, 2011 08:16 PM #198
Hmm,
Kung walang subwoofer: Go for a Powerbass ASA600.4 and then a Focal Access or a Morel Tempo 6. You should still have a couple of thousands left for wirings. I suggest you first bridge the 2 channels for more power and set the gains down (alam ng installer mo ito). In the future, if you plan to get a subwoofer you can always delegate channel 1 and 2 for the front speakers and 3-4 for the subwoofer.
I'm not a fan of V12 amplifiers, but most car audio beginners have passed through that stage. Hindi lang siya talaga "ideal" on the long run since mabilis lang sila masira. For straight 20k, you can get a straight Firland package (sub, amp, seps, box and wirings) from Candyaudio in Banawe pagnatatandaan ko. You can also opt for Pioneer speakers, JBL speakers since masnasa price range ito. JBL amplifiers aren't bad if you don't like to shell for the Powerbass ASA600.4 (which in fact, is quite clean power for its category) and JBL's subwoofer isn't bad too for the money. Targa's also quite good for the money kung marunong ka magtune but since you'll be having a stock headunit.. best to stick with flat-sounds-great brands like Morel.
JBL's distributor is... Perfect Circle in Banawe. Not sure kung meron sila mga JBL packages (di ko tinanong eh), but probably has. Go ask for Benedict. On the otherhand, Tsikotshop's prices isn't bad too. I'm not fond of the A/D/S happy hour promo since hindi na ganun ka"sikat" ang A/D/S. It used to innovate in the past, yes, but now it's like MBQuartz.. nabubulok na. On a personal note, Targas sound better really.
For budget meal setups, maybe a trip to Jeff Tan's Arareta Car Accessories would be best. Mashindi ka ma-rip off versus to Banawe shops (which would rip off unsuspecting buyers btw). Give him your budget and he'll recommend you setups naman.Last edited by jhnkvn; May 23rd, 2011 at 08:18 PM.
May 27th, 2011 11:30 AM #199
Because stock head unit of montero has no RCA output(casa don't include it for some reason), i only used line converter to put an amp and to power and upgrade speakers, last time, i installed DLS COM07-06-R6A component sets in the front and some coax for the rear fill, and amplify it, the whole sets, including the installation cost up to 21k, wala ring sub, so i have to push the speakers to produce a low frequency down to its limit without distortion..
The problem always down on installation, for conversion like from high to low, installer faces problems like static so he must know tricks to manage that noise, so always consider who to install, in conversion also lost the front and rear fading, if these happens, the quality of sound decrease and out of line..
- May 2011
- 20
May 29th, 2011 05:02 PM #200I just want to ask the experts if it's true that you need to turn down the volume of your I.C.E. before you turn off the radio to prevent damage when you turn the radio on again.
At RC Security Group, we provide trusted and affordable security patrols Brisbane to keep your...
Transcend Drivepro 520 - In and Out Security ...
