Results 141 to 150 of 3070
February 10th, 2011 01:36 PM #141
^ parang mali yung email add bro.
February 10th, 2011 10:10 PM #142
May alam ba kayong magandang seps and coax? I want it to be as simple as possible kasi and space-saver dapat ang magiging set-up, kaya i didn't ask for subs and amps. Sana medyo cheap lang kasi pang palit lang naman sa stock.
Btw, this is for Isuzu Crosswind.
February 11th, 2011 06:39 AM #143
bang for the buck.... targa.. ok na sa presyo.. pati tunog.. sulit na sulit.
February 11th, 2011 09:10 PM #144
*olidotcom
Ohh I See, may idea ka ba kung ano yung size ng speakers para sa harap ng crosswind?
February 11th, 2011 11:59 PM #145
sorry sir.. that im not sure.. best is check sa manual po? baka naka indicate dun...
afaik standard front door speakers are sized 6.5 inches.. dashboards are between or either 4 to 5 inches..
February 12th, 2011 06:52 PM #146
Bibilhin palang kasi yung car kaya wala pa ako idea kung ano yung size ng speaker. Plan ko kasi sana pagbili ng car, ipapaset-up ko na kaagad. Thanks!
May nakita din akong active subwoofer na nilalagay sa underseat. 4.9k lang with free installation. Ok na ba yun?
Also, maganda ba yung Ryan Audio na brand? Mura lang kasi yung nakita ko eh. Tingin ko kasi ok na pang-replace sa stock speakers.
February 13th, 2011 11:55 AM #147
sir's,
madali po bng mginit ung mga V12 amp??? im using a F705 first time ko
n-experience n ng-auto shut ung amp after 45mins of playing.
pki share naman po mga experience nyo s V12 amps...
many thanks po...
- May 2010
- 143
February 13th, 2011 01:14 PM #148madali po yan mag init lalu na kung woofer ang naka-kabit sa amplifier na yan
sir gamit ko pa kasi V12 1607 to drive my 2 10" subwoofer
dipende po kasi yan sa pag cocompatible ng ohms at RMS watts,, sa woofer at amplifier...
tip ko nalang sayo sir.. mag series connection ka ng speaker mo kung malakas uminit ang amplifier mo
bridge mo ung ch 1 at ch 2 ng amplifier mo at mag series ka ng dalawang woofer dun mo ikabit sa naka bridge na ch 1 at ch2 mo...
yung bakante na ch 3 and 4 pwede mo lagyan yon ng seps
at ung coaxials mo naman sa HU mo i-kabit yon para balanse ang tunog
at konting tuning nalang yan
- Jan 2011
- 40
February 24th, 2011 07:28 AM #149update guys, dati this is my setup.
ads 1689 (2k bili ko) seps HU powered lang. definitely mas ok kesa stock. then added an active subwoofer (NBN 8 inches) under the seat. mas ok naman kesa walang subs. hehehe
then after inquiring and reading so many topics about seps and amps eh napabili na rin ng amplifier. bumili ako ng v23 mrv-f805 (P2,300 - local lang hehehe).
so ginamit ko yung amps sa seps ko at bingo!!! ang laki ng improvement!!!! buong buo na yung tunog. then hindi ako mapalagay sa subs ko so napabili na rin ng 12 inches MB Quart Formula (P3,600) since meron na ako box. ang laki ng improvement overall.
so for only P8,450 without box eh na upgrade ko na sound system ko. sulit na sulit ang tunog. thanks sa mga tumutulong dito sa tsikot. ok na ako for the meantime. ipon mode na if ever balak mag upgrade sa higher models.
February 24th, 2011 10:12 AM #150
pa tulong naman mga sir. matagal ko na tong balak kaso walang idea. gusto ko i-DIY.
im planning to add another amp para 1 for sub and 1 for speakers(4).
current setup is 4ch amp powering 1set seps + sub.
ayoko na kasi magpa gawa sa shop para naman ma experience ko din DIY
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
