sell your 2way amp and replace it for a 4 way one!!! yep you can wire the 2 channels for the front seps then bridged the last 2 channels for the sub
what amp po ba gagamitin and anong seps and sub?
ask ko lang kung my case na pag nilagyan ng capacitor... hihina ba yung bayo?
guys, to my surprise, meron po ako nakitang mga fenton amps dito sa bulacan... kaso ang itsura di tulad ng mga nakikita kong fenton sa forums... ang design is parang linya linya tapos pag tinignan sa gilid, yung linya linya spells "fenton". ok po ba ito?
the amp models i saw were FA4300, FA4200 and FA2240
palagay niyo po, kasi i am planning to replace my v12 nv805 with a better amp. pwede ba yung mga yun? what fenton should i get?
i have 4 coaxes na 150 watts max (2 front and 2 rear) and a directed audio xtreme subwoofer na around 200wrms, 400w peak. lahat powered by my v12 nv805.
thanks in advance sa tips!
Given the specs of your 4 ohm speakers underpowered ang amp mo for front speakers na 125w pero halos pwede na sa likod na mga 80w. Pero try mo pa rin, for all we know it might just work.
You cannot run it at 2 ohms kasi given na ang speakers mo na 4 ohms. Kung 2 ohms ang speaker mo, mas ok sana kasi you will be getting 110w in effect per speaker.
Sorry but don't know about shallow-mount subs.
bro not familliar yung mga models na nakapost, yung may fenton na nakasulat sa gilid ng heatsink?
ito ba?
or ganito?
IMO: ang model no. ng fentons starts with the no. of channels then the watts
ex. fa4300 so 4channels 300watts divided by 4 75wx4
tingin ko kakapusin yung mga models na nakita mo try mo sa megamall or sa raon (Dai-ichi)
think yung f41000 bagay sa set mo para walang bitin
parang yung una sir. yun kasi pong nakita ko na FA-4300 and FA-4200, parang medyo lumang stock na dun sa electronics shop na napuntahan ko dito sa bulacan.
anyway sir...
yung f41000 means 4 channels 1000watts so 250watts max per channel?
ok lang po sa 150watts max na coax yun?
how much po ba brand new ng F41000 sir?
and where in raon yung dai-ichi?
thanks a lot!
IMO, save for a better branded amp like crunch. 6K ata yung PZi 100.4. or ipon na lang para sa 75.4. sell mo 805 pandagdag sa budget.
Sir, lumang luma na ung setup ko, namana ko lang
Eto ung nakakabit:
Infinity kappa kcs-120br 450Wmax 250Wrms 12" sub in sealed box
Ultra Sound Acoustic P100i 100W, 2 chan
Maganda tunog nung sub, buong-buo. Kaso gusto ko mas malakas pa
Eto ang hindi ko alam kung gagamitin ko pa (sobrang luma) hehe:
quart mobile 100.03kx (4" coax)
quart mobile 1113kx (6" coax)
Hanggang maari kc ayokong idispose ung sub saka ung amp eh (hindi ko rin alam kung paano ko didispose dahil wala nang bibili). Gusto ko sana from that setup, dadagdagan ko na lang.
15k po ang budget ko. Gusto ko dinig ung bass kahit 1 kanto pa ang layo. Kakayanin na kaya ito ng budget ko?
*For: OK lang mga 90w RMS lang naman yun siguro alalayan mo lang sa gain
Nasa 3.5k up ang alam ko dati kuha ko di ko pa navisit dai-ichi eh if ever pupunta ka san ka mangagaling?
*Forx: Yung ibang mga hardware meron,pero di lahat!!! try mo rin sa mga lumber stores
*Hamm: Sensya na di ko gaanong kabisado Crunch amps eh di pa ko nakagamit nun![]()
*toolights: sir either sa sampaloca (manila) or sa bulacan po ako manggagaling.
better kung sampaloc,sakay kang quiapo then baba ka sa overpass bago magsimbahan then bandang kanan may bldg.pasok ka may stairs sa bandang kaliwa dun sa 2nd floor makikita mo na yung sign board nila or tanong mo lang sa mga tindahan sa loob tuturo na nila
re: the slim type subs.There are subs that are quite slim. I believe Pioneer has a line. but from what I heard kulang sa low end frequencies kung ang habol mo deep bass. Midrange bass siya effective. Kung ayaw mong tanggalin or ipatong sa likod ng upuan, you could check out the Kicker S8L7. Mejo di na ako updated sa mga models pero kasya yun sa likuran ng pick-up naten. Or you could opt for placing the larger subs at the rear tray. But then you would need to have some way of placing the wires through the rear cab to the rear tray. And from some of the setups I've seen, it creates a lot of rattling noise.![]()
mga tsikoteers tanong lang...
If I have seps sa harap and 2way coax sa likod and pioneer 4950, if i add an ampli without sub, may difference ba sa SQ?
yup. meron po. mas maganda na!
mga tsikoteers:
I'm using a Pioneer 4950... pwede ba na di na ako mag amp then buy nalang ako ng sub? super budget ako but i wanna improve my SQ sa car... di ako masyado malakas magpatugtog, gusto ko lang maayos yung tunog... ok kayang sub lang?
meron kasi nakasulat dun na direct sub drive i don't know what that is for
tph,
are you reffering to the rca out? Thats where you connect the amp.
