Quote Originally Posted by userfriendly View Post
Is this your amp? http://www.cardomain.com/item/MTX4244 If that's it, you got a very nice, good quality amp. That amp is underrated, meaning it will pump out more watts than what its rating says.
I suggest you use your channel 1 and 2 to power your fronts and bridge 3 and 4 to power your sub. Power your rear with the HU or even do away with it. This way your fronts will get around 60 watts and your sub will get over 200 watts. Guess lang since this amp is underrated. That amp should give you more than enough power.
Alternatively, you can power your front and rear with CH 1 and 2. This will give your amp a 2 ohm load and you'll get over 90 watts. However, if you have a normal sized car, your rear speakers will tend to sound too loud.
opo yan po yun sakin.. actually matagal na po siya binile sa H.K. yun nga po bumile ako ng 12' na sony xplod para po magamit ko siya... mas ok po ba yun sakin kesa sa mga v12 na amp??.. kasi po balak ko buy ng xover at 4channel na amp para sa front and rear speaker ko.. ano po sa tingin niyo??? v12 na lang po ba ikabit ko sa sub ko oh yun mtx na lang po.. salamat
