Results 491 to 500 of 1645
June 17th, 2005 12:25 AM #491
Originally Posted by niwde11
the 1st rca is the sub out, the 2nd set are the input RCA's, the 2 below ang pang front and rear channel....thanks sa tulong nyo ha..
June 17th, 2005 12:09 PM #492
Originally Posted by trup
June 17th, 2005 03:32 PM #493
pag nag y connector ka 2 signals (mono)papasok sa amp mo left and right input .pwede ka pang mag dadag ng isang sub. pwedeng rin kung brdgegable yung amp mo + left channel - right channel output to your sub
June 21st, 2005 02:43 AM #494
http://www.bluespot.co.uk/stock_image/odsb8000a.jpg
anyone own or heard of this subwoofer? not really into sounds. pang add lang ng bass. my car car audio is all stock. clarion HU gen 2.5 pajero yung ride.. it cost 10k,
ODsb 8000A active sub main features:
Active subwoofer with passive radiator technology in extremely compact enclosure
The easiest way to more bass - amplifier and speaker in a box!
Twin 200mm drive units using passive radiator technology
Powerful 140Watt Class 'D' amplifier
Efficiency 4 ohm
Can accept line level (RCA) or speaker level input
Max. acoustic pressure (SPL * 100Hz) 136dB
Frequency response 60 - 120Hz
Phase regulator (0-180 degree) adjuster
Variable low-pass filter (60-120Hz)
Gain controls (0.2V - 8.0V)
Integral 20A blade fuse protection
ISSAC and power indicator LEDs
Dimensions 292w x 278h x 248d (mm). Weight 7.5kg
Two year manufacturer's warranty
Complete with fixing brackets, speaker level input lead, full fitting and operating guide
June 22nd, 2005 10:14 AM #497
acceptable. but then you'd probably have some problems with heat. But then it could be resolved with proper cooling.
June 22nd, 2005 08:25 PM #498
Originally Posted by PROMDIBOY
June 24th, 2005 03:39 AM #499
Sound Guru's, How do I connect my ampli to my HU if my HU doesn't have a RCA pre out? Amp is V12 1507. Thanks!
June 24th, 2005 08:26 PM #500
Originally Posted by ching
connect to rca cord use white for left channel and red for right channel
positive terminal is the inner part of the rca plug +(pointed head) ,outer part is the negative -(outer ring)
I disagree and wouldn't advise that. Additives get used up too, so topping up with the proper...
Coolant...
