Results 101 to 110 of 167
May 17th, 2013 01:23 PM #101
May 17th, 2013 01:33 PM #102
^ nilagyan nya ng slim type subs w/ teac speakers, teac seps and lightning lab amps. Deadening of 2 front doors. 11.5k inabot.
Sent from my GT-P3100 using Tapatalk 2
May 17th, 2013 01:38 PM #103
Jeff has an offer to replace my stock HU to a pioneer 2din HU, back up cam, headrest monitors for an additional 16k. Still thinking about it
May 17th, 2013 01:55 PM #104
May 17th, 2013 02:38 PM #105
Im still thinking kung mag amp and subs pa ako since di naman ako bass fan saka di ako malakas patugtog. Hehe.
Sent from my iPhone using Tapatalk 2
May 18th, 2013 01:41 AM #106
The primary purpose of OEM butyl deadeners is to lessen the resonant frequency of the panel by adding mass. By decreasing the resonant frequency of the panel, your midbass can then dig down deeper before resonating along with the music (aka bzzzz.. bzzzz..) The "sound deadening" properties is simply a byproduct of the added mass blocking off some percentage of the sound.
Decibel reduction is relative. You can deaden a Kia Pride and have great success but deadening a Lexus won't be that eyebrow-raising. To really reduce cabin noise, what you need to do is enclose your car like a bubble. This is the secret to upscale cars where they have thicker slates of everything from glass to sheet metal which they seal up nook and cranny afterwards.
In any case, if habol mo is reduction in cabin noise, the two most effective areas to treat are the floors and rear quarterpanels (tire noise).
If you'd like to research more, look into MLVs or mass loaded vinyls. However, don't use the term sa mga shops as they're unfamiliar with it. Just address them as butyl deadeners.
May 18th, 2013 06:33 PM #107
May 18th, 2013 08:55 PM #108
May 18th, 2013 11:27 PM #109
I was thinking the same thing before but because my stock HU cant really make the aftermarket seps sound good as the seps will be underpowered. Thats been demoed by Jeff. Maybe if i'll replace my hu there will be some difference. And according to Jeff, if the hu is replaced the steering wheel controls will not function anymore. In another thread, may nagsasabi na pwedeng mapagana ulit (controls) by adding up a console. Meron po bang ibang feedback w/ this?
May 19th, 2013 02:53 AM #110
1. "Under powering" and "sounding good" isn't correlated to one another. Sounding good is directly proportional to your tuning, that is, unless you're pushing the volume knob a bit too high and your driver starts distorting. You can get great sounds off your stock head unit's 18W, problem is that you can't listen to loud music.
2. What you need is a steering wheel interface. Locally, I think one of the more famous brands is PAC (Pac-audio.com Products | iPod Integration for your car and More by Pac-Audio - Connecting you to the future).
Xiaomi E-Car
