Results 11 to 20 of 151
April 19th, 2022 04:03 PM #11
Ah yes, local support. Totally understandable. That's the con of getting one from oversees.
I think you can request for one without the branding. Same here ayoko nakalagay "Navitopia" sa head unit and luckily they gave me one without any branding.
Or go with one of your original ideas and get a branded unit with Carplay and Android Auto. That's actually the solution we did because I gave up on the Android head unit. Sold our navitopia and got a pioneer avh-z5250bt instead. Even after selling the car the new owner liked the head unit and didn't change it.
April 19th, 2022 04:22 PM #12
May 9th, 2022 11:32 AM #13
Had the Growl Premium installed yesterday.
The new Hazard button looks cheap!
But the head unit is way better than AVT
May 19th, 2022 05:14 PM #14
to those using Android Head Units.
Did you turn on your Google Play Protect?
June 7th, 2022 12:18 PM #15
A month after using my Growl Head Unit (4/64)
Observations:
Radio volume is slightly higher than the volume of Waze (even with the loudness off). No issue if I use Spotify.
Same volume issue if I use the radio with Android Auto/Apple CarPlay.
It will turn off and disconnect when I start the engine.
The unit will take some time to turn on, halos nakalabas na ako ng parking before I can use the unit.
Reverse camera is a split second slower compared to my AVT head unit
Yes you have an Android device in front of you... (however)
You need to update the Apps 1 by 1. Somehow, the update all doesn't work
Android Auto keeps disconnecting (wireless)
I'm used to using gestures on Android and Growl does not support it.
I also cannot delete unused/empty home screens
And I can't seem to figure out how to add/switch user profiles... (anyone who uses the car will see my Google history)
You can't remove all Apps (messages and contacts feels weird)
- Sep 2010
- 2,867
June 23rd, 2022 06:00 PM #16Been seeing ads of Astral Android head unit. Anyone here using it? Any feedback?
- Jun 2012
- 269
January 5th, 2023 02:22 AM #17
- Jun 2010
- 72
January 9th, 2023 05:43 PM #18
February 13th, 2023 11:36 AM #19
Warning when buying China Android Head Units even from local vendors...
Android Head-Unit faking its hardware specifications | Team-BHP
Got an Astral HU "newer and more expensive" model ... claimed to be running on 1.5 A7 quad core running on Android 13...
Ran CPU-Z on the unit.
Turns out running on 1.12 ghz A7 quad core circa 2013 and Android Level 29 aka version 10 only...
So better check their promo 7999 unit with CPU-Z app, baka 1 gb ram or lower Android version lang tinatakbo kaya cheap.Last edited by Monseratto; February 13th, 2023 at 12:31 PM.
- Dec 2019
- 2,072
high idle RPM at engine start
