test
Page 74 of 81 FirstFirst ... 2464707172737475767778 ... LastLast
Results 1,461 to 1,480 of 1618
Thread: Avanza Periodic Maintenance Service (PMS)
  1. #1461
    Join Date
    Sep 2005
    Default Re: Avanza Periodic Maintenance Service (PMS)
    you dont need the windshield washer fluid..
    yung mga nag papa PMS sa casa.. i suggest you buy Toyota's privilege card.. 500 lang yata yun tapos pwede mo agad magamit.. valid for 1 year.. 10% discount on parts, accessories and labor w/ 1 free towing.. libre pa pa estimate pag may damage for body and paint..
  2. #1462
    Join Date
    Feb 2012
    SPEEDOMETER CABLE PROBLEM...
    Hi to all!
    Share ko lang din ang na-experience ko when the speedometer cable of my 3.5 year old avanza 1.3J got broken.
    Paakyat kami ng Marcos Highway when I noticed my speedometer is not working anymore. After a few meters, I felt like the engine stalled. The feeling is like "nakabit mo sa neutral ang kambyo". Then I have to go on shoulder. After a few seconds ok na ulit ang engine.
    After a few hundred meters uphill, lumabas ang "check engine" indicator. Nothing happened since I was thinking then that it's because of the broken speedometer cable. Stayed in Baguio for another 3 days.
    Pagbaba na namin, the travel was problem free except when we reached a portion of Bocaue along NLEX. Again, nag-stall ang engine kaya I need to go on shoulder again. It happended 3 times along that stretch. Nakauwi naman kami safely sa QC. I called up a friend and suggested that the engine stalling is caused by the computer box not detecting any speed from my car. At prolong RPM, it stops the supply of fuel.
    Nagcanvass ako sa TYT Q.Ave but out of stock. Even in Celica Genuine Parts along Araneta. They gave me a price of Php 2600 but I have to wait for 7 days.
    A friend referred me to THK in Banawe. Katabi ng Toyorama very near E.Rod. They have a replacement cable na Made in Japan. Php 600 only. I have no choice so pinakabit ko sa trusted mechanic ko sa Araneta. Labor fee is Php 500.
    The next day, we traveled to Pampanga. No more stalling.
  3. #1463
    Join Date
    Jan 2008
    parang mali yata ang program ng ECU ng avanza pag ganyan.. hindi dapat mag stall ang engine kasi hindi naman part ng engine ang speedometer cable... minsan nga may busted na sensor pero hindi naman dapat mamatay ang engine.. iilaw lang dapat ang CEL pero dapat tuloy ang andar nyan.. kasi delikado pag nag stall ang makina...
  4. #1464
    Join Date
    Feb 2012
    Ako din nagtaka kung bakit pati speedometer cable will bring stalling problems. It's really dangerous lalo na sa NLEX high speed driving ang mga kotse.
    So far so good yung Made in Japan replacement I bought. Mahirap lang ikabit since the cable is located inside tha dash.
  5. #1465
    Join Date
    Sep 2005
    had my 65K PMS today at Toyota Shaw..
  6. #1466
    Join Date
    Feb 2012
    This is how I periodically maintain my Avanza 1.3J 2008 model:
    - I change spark plugs every 10,000 kms. I now use the Denso XU22EP-U replacement spark plug. It costs Php 110 each.
    - I replace the air filter every oil change (i.e. every 5,000 kms.) since I am only using a replacement air filter but resembles the original Toyota air filter. It costs Php 250 each only.
    - Labor charge from my trusted mechanic: Php 200 (engine tune-up)
    - Change oil every 5,000 kms. using 3 liters of Castrol Magnatec 10w-40. Php 300 per liter.
    - Change oil filter every oil change using Vic oil filter. Php 200 each.
    - Labor charge from my trusted mechanic: Php 250 (oil change)
  7. #1467
    Join Date
    Aug 2005
    Quote Originally Posted by batch View Post
    Basically same tayo, iyon lang nga nasa 19,000km na ang plugs ko, papalitan ko sa next change oil. dati talaga, every 10,000km ako palit plugs. first time ko ginawa ng more than 10,000km.so far ok naman.
    naka aftermarket filters ako kaya madalang nag palit.
    3 liters of magnatec and vic oil filter din.
    kaso, every 5,000 km change oil, palinis ng brakes. gamit pa ng 3M brake cleaner.
    btw 2007 avanza J. 4-spoke na ang manibela with driver aigbag. odometer is now at 109,XXX km.
  8. #1468
    Join Date
    Jan 2010
    Default Re: handbrake button problem
    Meron ako available pre fabricated stock ng Avanza hand break button. 500 pesos lang. Alumnium alloy material kaya mas matibay sa plastic na nakakabit sa avanza natin. Walang hand break button sparepart para jan ang toyota. Full hand break replacement ang offer nila. It will cost you 4,000+ pesos. Meet up anywhere as Alabang or dito sa SM Molino kung interested ka. Exact size. Ikakabit mo na lang. Na offer ko na rin ito sa Toyota Dasma as replacement part. Txt to 09272711420 kung sure buy ka na. Thanks.
  9. #1469
    Join Date
    Apr 2011
    sir pwede ba shipping? QC kasi ako
  10. #1470
    Join Date
    Jan 2010
    Sorry, cash on delivery. Talagang meet up lang sa Festival Mall Alabang or Alabang towncenter ang pinaka malapit sa akin. 6 pieces na lang ang available. Probably kung may bibili lahat ng 6 pieces at 1 place sa QC possible kong i drop by.
  11. #1471
    Join Date
    Sep 2005
    sir attend na lang kayo nang EB sa March 31 sa MOA sa may starbs e comm bldg, 6pm.. dala kayo marami.. sigurado maraming bibili nyan..
  12. #1472
    Join Date
    Jan 2010
    try kong magpunta sa March 31 sa MOA. 6 pieces lang kz un stock ko ng avanza hand break button. Nagkataon lang nasira un sa hand break ko kaya nag fabricate na rin ako ng extra para sa masisiraan gaya ko. Mahal kasi ang buong hand break replacement ng toyota avanza na sa 6K na raw sa ngaun. Thanks sa invitation.
  13. #1473
    Join Date
    Sep 2005
    baka pwede ka pa pa fabricate nang madami at least 10 more.. marami bibili nyan don..
  14. #1474
    Join Date
    Aug 2009
    how much po kaya abutin yung 40k pms, due na kasi for pms tong avanza service vehicle sa opis,
  15. #1475
    Join Date
    Sep 2005
    basic lang.. regular oil.. change fluids.. mga 9T lang yan sir or less.. w/o aircon cleaning.
  16. #1476
    Join Date
    Jan 2010
    On Avanza hand break button, let me see kung pwede ko pang paki usapan un gagawa ng maihabol. Mahirap kasing maghanap ng Aluminium Alloy na material. Thanks.
  17. #1477
    Join Date
    Aug 2009
    tnx sa info sir
  18. #1478
    Join Date
    Jun 2006
    Quote Originally Posted by jojomonsalud View Post
    Yung sakin inabot ng 11K last March 2011. Replaced all fluids, spark plugs, front brake pads etc...
    Magkano ba 50K km service?
  19. #1479
    Join Date
    Sep 2005
    mura na lang yan parang 10K PMS.. kung regular oil lang baka less than 3T..
    Quote Originally Posted by userfriendly View Post
  20. #1480
    Join Date
    Aug 2005
    will have my regular change oil this week end. 110KKms. will now have my plugs changed. 20,000 km na :D
Posting Permissions
  • You may not post replies
  • You may not edit your posts
