Results 101 to 110 of 251
Thread: Avanza Engine Problem
January 28th, 2011, 10:16 PM #101
- May 2009
- 28
Re: Avanza Engine Problem
this happened nung sunday twice! ..and then kanina..
as far as i can remember nka 2nd gear din ata ako noon..tapos medyo paahon ung daan so need ko edepress ung accelerator after which naramdaman ko na lang na sobrang rev na at taas rpm, ginawa ko nagshift agad ako neutral and then inapakan ko ulit ung gas pedal baka lang huminto ung pagrev niya. Pero ayaw pa din, ang ginawa ko pinatay ko makina tapos start ulit ayun nawala.
kung sa floor matting, noon pa kasi yun ang matting ko, kung yun ang cause so dapat noon pa nangyari yun.
sobrang worried po talaga ako, kasi sudden acceleration yun what if nasa highway ako and then biglang mag ganoon ulit?
nareport nyo na po ba yan sa casa? i was planning to bring mine tomorrow kaso baka wala ako mapala.
ano po kaya ang pwede nating gawin?
January 28th, 2011, 11:20 PM #102
January 28th, 2011, 11:24 PM #103
pssst, paahon ba ay pababa? sabi ni google paakyat....hehehe
To ma'm ca3tyryn,
Normal po na aangat ang rev nito(approximate between 2500~3000rpm) kung biglang full clutch(or neutral)
nasa full power ang engine during upward kapag biglang nawalan ng load, tataas talaga ang rev
At aangat po lalo kung tapakan mo uli ang accelarator...
Just release the accelarator, babalik po yan sa normal rpm.
Reset nyo din po ang ECU...Last edited by xda2jojo; January 28th, 2011 at 11:43 PM.
January 29th, 2011, 12:29 AM #104
- May 2009
- 28
January 29th, 2011, 12:33 AM #105
- May 2009
- 28
January 29th, 2011, 01:35 AM #106
not at all, unless tama po ang timing nyo sa driving...
as i said normal lang po yan kung sa situation na nagrev po tayo ng maigi dahil paakyat eto, tapos bigla po natin tapakan ang clutch dahil nasa itaas na kayo, natural po na aangat ang rpm dahil wala napong load ang makina.
again...mas lalong magrev po eto dahil tinapakan nyo uli ang gas at assuming naka full clutch pedal napo kayo...
purpose po na e-reset ang ecu para bumalik siya sa default or factory setting,
kumbaga pa marefresh, pero di po ibig sabihin na maging "smooth" agad ang takbo ng makina, babasahin po uli ang lahat data na galing sa mga sensor at doon na timplahin ng ECU ang tamang setup...
January 29th, 2011, 08:56 AM #107
- May 2009
- 28
January 29th, 2011, 04:55 PM #108
- Jan 2011
- 5
sir, baka pde makahingi info bout sa handbrake ng avanza...nasira kasi pindutan kelangan ba talaga palita yung buo o may remedyo pa.
January 29th, 2011, 05:37 PM #109
January 29th, 2011, 05:48 PM #110
- Jan 2011
- 5
nabasag eh...sa casa ang sabi kelangan palitan yung buong handbrake. tumingin ako sa evangelista ang suggestion palitan ng galing sa lumang toyota yung buong handbrake
Having problems posting images as well.
Problems with viewing Tsikot on non-Chromium...
