Results 131 to 140 of 251
Thread: Avanza Engine Problem
February 9th, 2011, 10:22 PM #131
Re: Avanza Engine Problem
any ideas what's causing the ik ik sound kapag apakan yung clutch? ganun din avanza namin (2007 1.5G) ngayon, seldom used lang kasi (2-3 days in a month). usually nawawala din yung ik ik sound after driving it for 1 day but after a long period of being idle balik naman si ik ik. ang source ng ik ik hindi sa clutch pedal assembly sa loob ng cabin, sa engine bay talaga i think sa loob ng hmmm clutch master ba tawag dyan? yung big black na bilog nakadikit sa firewall. possible kaya this is caused by using different brands of brake fluid (preston dot3 to stp dot3). pinaayos ko kasi yung brake ko months ago yung gamit ng shop pang refill stp dot 3 na brake fluid.
February 10th, 2011, 01:40 AM #132
February 10th, 2011, 01:50 AM #133
February 10th, 2011, 09:21 AM #134
sir jaspi already done that, using wd-40 and silicon oil, tinanggal ko na yung cover under the steering column to check baka dun sa loob umiingay, sa labas talaga galing, end of the month paguwi ko ng bacolod will have my trusted mechanic check on it.
February 10th, 2011, 11:00 AM #135
hehehe....di ko sinabi na may sinabi ka.
Majority of DIYers includes me and some mechanics don't know how to handle or use the carb cleaner,
As per my experienced, more than 10years na ako nagbubutingting ng makina at computer box ng lancer(92, injector) ko, engot parin ako sa paggamit ng carb cleaner, doon ko nalaman noong nasira ang idle control valve embedded inside the throttle body(i don't know if our avanza mayroon ganyan), sa sirang yan ay nagmalfunction ang idle ko including cold start probs.
so i don't recommend it using to our avanza na non carburetor type engine,
or maybe to some expert, i experienced it, lesson to learned not to use it anymore.
Maybe if you recommend it to use, please includes procedure.
Ang mangyari kasi, once nasa kamay na natin ang carb cleaner na spray type.
Yon spray doon at dito ang gagawin, noob ako, at wala sa procedure ng Can nakasulat, walang precaution or maybe they are(maker) assuming sa carburetor talaga gagamitin.
Ayon sa isang iglap, goodbye TB.
Binigay lang kasi yon sa bro ko ang carb cleaner na may lancer(carburetor type) din
may nabili ako na pang Tb cleaner sa ace, plastic and rubber friendly.
one example of using wd40,
noisy door hinges, other replied, spray it with wd40.
spray agad, damay ang door trim, tumulo sa ibang part, noob e, ayon deformed ang trim, sira ang pintura.
sana includes naman ang proper handling para sa mga newbie.
peace...Last edited by xda2jojo; February 10th, 2011 at 11:09 AM.
February 10th, 2011, 11:56 AM #136
bakit lagi nababasa air filter cover every car wash? ano kaya pwedeng gawin doon sa ilalim?
pwede ba gamitin wilkin distilled water for tapping up GS battery?
February 10th, 2011, 01:06 PM #137
normal lang yan sir, kahit sa ulan basa whole engine.
kung worry ka baka papasok sa loob ng filter, normally may papasok talaga konti at di eto maiwasan pero may drain hole naman eto
At di naman eto basta basta papasok sa throttle dahil sa filter.
best thing to do, pagsabihan ang car wash boy na hwag itutok doon sa grills ang pressure hose.
yes, pwede kahit absolute na distilled water, or any distilled water na available, pwede din rain water or tap water na overnight na galing sa ref, recommended morning ka maglagay dahil baba ang mga minerals nito, wag mo lang ibuhos lahat dahil useless din.
same as pang top up sa coolant...
And never use battery solution, para lang yan sa mga bagong batt na di pa nagamit.Last edited by xda2jojo; February 10th, 2011 at 01:15 PM.
February 11th, 2011, 10:26 AM #138
February 11th, 2011, 10:54 AM #139
chrome.....
February 11th, 2011, 06:35 PM #140
Safe ba sa emblems yung bug and tar na made from HCl? Yun kasi yung kinuha ko. For my polishing set...
"Tamang OC lang" - a newbie's guide to car...
