Page 4 of 14 FirstFirst 12345678 ... LastLast
Results 31 to 40 of 138
  1. #31
    Join Date
    Aug 2005
    Default Re: Avanza Check Engine Light
    Duplicate post
  2. #32
    Join Date
    mga sir,
    baka yung engine management module ang sira, may na basa kasi akong article tungkol dyan... hanggang nasa warranty period pa dapat kulitin yung kasa na gawin kasi nasa computer box yung module, dalawang klase daw yan umiilaw yung malfunction light or yung rpm d stable bigla siyang magdrop kala mo nag-auto yung aircon pero pag inobserbahan di naman...ang problema alam ng kasa yung ganyang problema, nahihirapan lng sila kumuha ng replacement parts kaya nag-papalusot sa explanation
  3. #33
    Join Date
    Apr 2008
    mga sir... i try nyo alisin yung connection sa battery for about 20mins. para mag reset yung computer box..dpa naman nangyari ito sa vanzy ko pero sa lancer ko e nangyari na itong ganito kaso...ayun nang mag reset di ko na ulit nakita na umilaw yung check engine light.
  4. #34
    Join Date
    Aug 2005
    Quote Originally Posted by Cherey View Post
    Binabalak ko nagawin itong method na ito dati pa. hindi ko lang naasikaso.
  5. #35
    Join Date
    Aug 2005
    duplicate post
  6. #36
    Join Date
    Aug 2005
    Last Sunday, I have disconnected the negative terminal of the battery for at least 5 mins. Unfortunately no effect. nanduon pa rin ang paminsan-minsan ilaw ng check engine light.
  7. #37
    Join Date
    may na-fla flag na error don sa air intake.. pero ni check naman nila wala daw problema.. ni check din daw nila lahat nang sensor.. mahigpit naman daw lahat..
    a diligent serviceman would replace the related sensor to eliminate the possibility of a flaky sensor ... an intermittently failing sensor is very likely to pass a go/no-go test so the only way to verify the diagnosis is to replace it
  8. #38
    Join Date
    Sep 2005
    pansin ko din.. madalas na umilaw yung MIL ko.. dati eh parang once a day lang.. ngayon minsan nag susunod sunod na.. 16T na odo ko.. so 1T kms ko na ni o observe.. tinawag ko na ulit sa Toyota shaw.. sabi ko kung walang problema eh di baka sira yung sensor kaya ilaw nang ilaw.. i check daw nila ulit sa computer.. ipasok ko daw.. kung wala talagang problema.. eh papalitan yung sensor daw.. kaya lang 3 days daw yun.. tsk tsk tsk tsk
  9. #39
    Join Date
    Dec 2007
    [RANT MODE ON]
    3 DAYS JUST TO REPLACE A SENSOR?!?!?! Pinaglololoko na tayo ng mga iyan!
    Pinatatagal lang nila para hindi mo na ipasok sa casa, siyempre, malaking abala iyung 3 araw na wala ang sasakyan mo...
    [RANT MODE OFF]
  10. #40
    Join Date
    Dec 2007
    I think dapat at least 20 minutes ang pagtanggal, Pres.
    Gawin mo na kayang 1 hour or overnight for good measure?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
