Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    di ba pwede mo pa din naman gamitin yung plate protector but without the clear cover? so huwag mo lang ilagay yung plastic lens nya ok na kasi cover lang naman ang bawal.
    medyo vague ang ruling dyan bro. any alterations daw ng nasa plate that may block clear vision of the figures ang ruling eh.
    traffic enforcers may read the frame as an alteration.
    Sep 2013
    Quote Originally Posted by dishcom View Post
    Kaya yan.. dahan dahanin lang.. para hindi ma gasgas.. or sa likod mo e pihit wag sa ulo..
    vise grip lang katapat nyan.
    not a good idea. mo lu-loose thread ang bolt dahil sa pressure apply ng vice grip sa bolt. so mas mahihrapan kang pang to loosen the bolt besides the nut in your bumper loose thread also.
    I did it once by removing the front bumper. Sa rear plate naman, kaya i-access thru the trunk. So sa likod ng nut, you could use vise grip but I do suggest that after removing it, cut a slot on the bolt so that you could use an ordinary flat head screwdriver to tighten back the bolt.
    Nov 2014
    I've seen this done. Just carefully use a flathead drill bit on the bolt then unscrew with a flathead screwdriver.
    Oct 2009
    suppose to be you need to buy new set of screws from the lto. ang tanong e kung may supply. malamang parang DL at plate din lang yan, wait ka 6 months.
    sa akin nga mag renew na ako ulit ngayon march wala parin ung plate number.
    Jun 2011
    A long tipped vise grip + masking tape can lossen it easily.done it many times.
    Feb 2014
    Use a steel saw to etch a flathead screwdriver groove sa harap ng screw, then use a flathead screwdriver to remove it. That way, pwede mo ibalik ang dating screw. Yun nga lang, halata na tinanggal mo.
Tips on how to remove the new white LTO plate with the fixed screws?
