Results 11 to 18 of 18
February 12th, 2016 01:38 PM #11
di ba pwede mo pa din naman gamitin yung plate protector but without the clear cover? so huwag mo lang ilagay yung plastic lens nya ok na kasi cover lang naman ang bawal.
February 12th, 2016 01:52 PM #12
February 12th, 2016 05:45 PM #13
February 12th, 2016 05:47 PM #14
I did it once by removing the front bumper. Sa rear plate naman, kaya i-access thru the trunk. So sa likod ng nut, you could use vise grip but I do suggest that after removing it, cut a slot on the bolt so that you could use an ordinary flat head screwdriver to tighten back the bolt.
February 13th, 2016 12:12 AM #15
I've seen this done. Just carefully use a flathead drill bit on the bolt then unscrew with a flathead screwdriver.
- Oct 2009
- 2,271
February 13th, 2016 04:37 PM #16
- Jun 2011
- 134
February 16th, 2016 04:22 AM #17A long tipped vise grip + masking tape can lossen it easily.done it many times.
- Feb 2014
- 10
March 17th, 2016 11:33 AM #18Use a steel saw to etch a flathead screwdriver groove sa harap ng screw, then use a flathead screwdriver to remove it. That way, pwede mo ibalik ang dating screw. Yun nga lang, halata na tinanggal mo.
sinabi moh! i hardly see my children now. when they were young, schedules were more predictable.
Traffic!
