*crosswind: As long as the problem is ON the paint surface only, that can be corrected without repainting the panel.
If you can, take a close-up photo using your camera's macro mode. Try it with or without flash, whichever gives the better result.
* red_one here's a clearer photo can you identity if it's faded/oxidated/etched watermarks?
Type I Water Spots are mineral deposits sitting on top of the surface.
Type II Water Spots are actually holes or etching that are in the paint.
Type I Water Spots, or mineral deposits bonded to the surface can be removed using detailing clay while Type II Water Spots, or etchings which are below the surface must be removed using a compound or polish because you have to remove a little paint surrounding the etching to level the surface.
Mga boss. Question lang. After ko ipaoptiguard yung oto kay big berts. Ano pwede ko iapply sa kanya? Pde ko ba gamitan ng nanogloss at nanosliq? Thanks!
Posted via Tsikot Mobile App
Ask ko lang kung anong magandang pangtanggal nang silicone sealant sa car surface without affecting the paint. Pudpod na daliri ko, and may mga tira tira pa rin eh.
Mga sirs ok lang ba ganitong combination: kaio + megs ulitimate wax? Thanks!
1. The curing process starts the moment you apply the layer.
2. You don't need to immediately wipe down the wax after you lay it. In fact, I rotate on a 2-3 panel basis. The only body panel I wipe down after laying down a layer is the hood due to its area.
3. The reason why the KSG is easier to remove is probably due to the morning dew that happens around the early mornings. Moisture softens up the wax and makes removing any PITA wax a breeze.
I urge people not to be so OA in their car's finish since you'll understand over time that you'll still have paint defects coming from minute rocks, gashes, scratches, etc. eventually over time.
Here's me whipping out a 3M Liquid Wax for use on the hood and trunk only.
Is my car's finish perfect? Far from it. I still need to clay that since it has 9-months worth of surface contaminants on the paint. Run your fingers on it and the surface is actually coarse. It's also not white as it was before and I need a cleaner. It's also 5-months without a protection layer. Thank god I'll get to finally use my Php2.5k Big Berts GCs (hurray no expiry) after my CASA repair next week. Two-step detail here I come!
Oh, don't worry, I'm not that patient yesterday so I just waxed those two panels only. Why these two? Because these are the parts that's critical. Doors? Nah..
P.S. "Famous" products are over-rated. I dunno why people won't pick up this bottle in ACE hardware when it's on sale. Hell, am I the only one who actually bought two of this?
Maybe overshadowed by other brands locally but 3M is a famous brand among body shops. They offer a complete line up of products from body repair to detailing, and even under-coating.
Does anyone know how much the microtex duster costs and the orange terry cloth?
