Page 21 of 203 FirstFirst ... 111718192021222324253171121 ... LastLast
Results 401 to 420 of 7833
    *umi001 Yeah I was trying to avoid that. I don't enjoy waiting for my stuff to arrive. I guess its either pay more locally, or pay less but wait for a month. Thanks.
    Sep 2012
    Thanks sir nivraarvin, Stavros and umi001. I'd probably try the easier ones to apply first since I'm gonna do it by hand hehehe... Pag sanay na, I'd like to try out collinite. 😊
    finally, i was able to try and apply yesterday the collinite 915 after doing Step 1 and 2 of Mothers. took me 5 hours to detail the whole car. Madali lang naman apply and buff basta manipis lang ang application using the foam pad na kasama. Basta lang small portions at a time or half panel wax on then wax off agad. parang mas madulas to the touch yung nano glos or mothers carnauba wax than the collinite. the durability remains to be tested. sana nga more durable as claimed to last more than one week.
    Aug 2008
    Quote Originally Posted by yourman_2nd View Post
    It should - easy six weeks for me, before I stripped and applied a different LSP. It's also pretty easy to remove, even if you apply to the whole car, as long as you apply really thinly.
    thanks * umi. noticed yesterday that after the curing period, the collinite wax made the california duster slides more easily and smoothly than with the nano glos or mothers carnauba wax. seems the extra cost is really worth it. will apply the nano glos this weekend to top off the collinte and see what effect it will have.
    Nov 2011
    does the mothers' carnauba cleaner wax needs curing time?
    Apr 2012
    Hindi natanggal ng nanosil mga swirl marks, light lang naman pero ayaw talaga. Hand buff lang sya.. Kakapagod! After applying i applied 476 pero hindi ko na nasama ung roof. Ok lang siguro noh? Biglang tinamad e pero may beading naman pag wash ko. :-)
    Anong product/s kaya na matatanggal swirl without damaging the clear coat? Thanks!
    Sent from my Galaxy S using Tapatalk
    Quote Originally Posted by MikkiW View Post
    Kung by hand di talaga matatanggal sir, pero kung gagamitan natin ng rotary, for sure mafi-fill up yung swirls ng paint niyo.
    There have been lots of road reblocking here in our place and andaming talsik ng semento ng paint ko particularly doon sa part na tinatalsikan ng putik ng tires. Tanong ko lang kung paano sya safe matatanggal? Previously kasi natuyuan ako sa lower part ng door I had no choice but kutkutin sya kaysa mas tumagal pa. Medyo may light scratches pero mas pipiliin ko yun kaysa matuyo ng husto yung semento.
    Aug 2008
    Sometimes, if the cement hasn't had time to completely set, soaking in vinegar (acetic acid) can help soften the cement enough that a pressure wash will remove it. I've read that you can also use WD40 to help loosen the cement bond. There's a product sold in the US, a cement dissolver that various people on the different detailing forums have used to good effect, but I've not found anything similar over here (I've done a bit of research, reading up and have had some actual experience on this recently, if you've read my thread on PD ). Otherwise, you'll have to use physical force to remove them - using your finger or a plastic razor blade.
    Quote Originally Posted by umi001 View Post
    Yung sakin natuyo sa glass at paint, binabaran ko lang ng car shampoo then kutkot. Buti natanggal, kasi para siyang drops at parang "beading" form siya, siguro dahil nadin sa wax at medyo sariwa pa, kaya natanggal ko at walang marks.
    BTW, kamusta na yung kotse niyo sir umi?
    What's the name of the thread sir umi? Thanks for the inputs. Naalala ko bigla may dumi pa pala yung kotse and I have to wash it baka may semento na namang nadikit. Good thing I just waxed with 476 last Saturday. Malaking tulong ang wax talaga, di agad dumidikit yung semento sa paint.
    sirs newbie here ask ko lang if ok lang ba yung steps ko
    1. wash
    2. clay
    3. wax (synwax FX mothers)
    4. step 2 (mothers)
    5. step 3 (mothers)
    6. top coat reflections (mothers)
    Thank you in advance mga sirs!
    Quote Originally Posted by roymark_salazar View Post
    1. wash
    2. clay
    4. step 2 (mothers)
    5. step 3 (mothers)
    Go with 12435
    Quote Originally Posted by nivraarvin View Post
    Go with 12435
    thank you sir!
    Aug 2008
    1. wash
    2. clay
    4. step 2 (mothers)
    5. step 3 (mothers)
    1, 2, 3 or 4 (Synwax contains cleaners that will remove some, if not all of the glazing oils of #2), then 5 and/or 6 (you can use both, but I'd probably use just one).
    Aug 2008
    It's my got into an accident thread. And yes, having a good LSP helps keep the cement from adhering too much.
    Apr 2012
    Any products pang tanggal ng swirls and scratches sa paint? Non abrasive sana try ko i detail ung car. Medyo may mga light scratches kasi.. Thanks for the help. :-)
    Aug 2008
    Non-abrasive products will not remove scratches and swirls - they will only hide them temporarily, and usually only the really light swirls. The only way to remove marring from the paint is to polish it down to the level of the defect.
    If you just want filling products, you can get NanoGlos or Mother's Step 2. For actual polishes, start out with Meguiar's Ultimate Polish - it has some polishing ability, plus a load of oils that can also do some filling. If needed, you can move up the Meguiar's consumer polish chain, depending on the severity of the marring (from UP to Swirl-X to Scratch X 2.0 to Ultimate Compound).
    Apr 2012
    Thanks sir umi, what about the klasse twins? Is it worth considering?
"Tamang OC lang" - a newbie's guide to car appearance maintenance
