ano sir color ng car mo? alam mo kung saan galing yang yellowish na marka? baka makuha ng kerosene yan sir. mura pa. if not, kelangan mo na ng polish or cleaner wax. meron nabibili na nasa sachet lang sa blade at ace para sakto lang sa gamit mo.
Step 1 in the 3 steps system - Wax Forum
the link above explains that the Mothers Step 1 Polish/Paint Cleaner is a polish but not abrasive. Meaning, it cleans out the haze and imperfection of the top coat but does not totally remove swirl marks or light scratches. so based on this, it is safe to use unlike polishing/rubbing ompounds or scratch removers..
Mothers® California Gold® Pure Polish - Step 1
but on the link above states that it should be used once or twice a year only. well that is for cars used in the US where in the environment is much cleaner than the metro manila's. meaning the top coat does not haze nor degenerate as bad as the cars here.
i'm no expert but to be safe, using the paint cleaner/polisher Step 1 should be used as advised by Mothers at most 2x a year.
But for me, i use it as i see the need to remove the haze and imperfections of the top coat, but keeping in mind not to apply very hard so as not to thin out the top coat. as in tamang OC lang sa pag apply. But i use the glaze Step 2 more often when there are swirl marks and hairline scratches to HIDE these before waxing.
also, after getting introduced to microtex products here, i often use the nanosil, nano glos, and nanosliq more than the mothers products. not only cheaper but also easier to apply and buff.
but since di masyado maulan ngayon, i use the QD/nanosliq more often (weekly or after a light breeze when my car was just waxed) to keep the paint shiny and protected.
guys add ko narin sa question
madali ba mag clay? 6months na yung innova namin, dami na imperfection like dun sa hindi maalis na cement / paint dun sa bandang ilalim ng doors
asphalt etc...
worth it ba bumili or paubaya ko sa detailing shops?
paadvise naman po...
nagpapaint ako ng 4 panel (2 doors, quarter panel, yung side nung sa hood) lahat yun sa isang side lang...paguwi ko tsaka ko nanotice na ang gaspang ng roof, trunk and hood ko.you think overspray?
texted the owner of the shop and ibalik ko daw para pabuff nya yung gumaspang...
may question is kung ok ba pabuff ko nalang dun para wala na ko bayaran or go to detailing shop to have it clayed?(not sure kung nakukuha sa claying yung overspray)
Question, every kelan kayo nag aaply ng KAIO and KSG? Isip ako ng isip kung bibili ba ako:-) thanks guys!
Sent from my Galaxy S using Tapatalk
Ang kaio po eh chemical cleaner, usual na inaalis niya eh oxidation, even fine swirls...
Pero ang clay, tinatanggal niya yung mga dumikit na contaminants sa paint mo.
May hindi matatanggal ang clay na matatanggal ni kaio and vice versa.
Saka iba ang kinis pag nag clay, parang pwet ng baby![]()
to quote again the website of mother's:
If you're dealing with minor water spotting and lightweight scratches or perhaps atmospheric deposits or light chemical etching from bird droppings, an entry-level cleaner/polish such as Mothers® Pre-Wax Cleaner Step 1 (the first of its three-step system) will do the job. This light cleaner/polish is minimally invasive but still effective, consistent and easy to use. It can be applied several times in a row to slowly erase light surface damage—so polish to your heart's content!
