Correct. Steel wool #0000 Super fine will not scratch glass. That is different from the steel wool used for dishwashing.
Sent from my ASUS_Z010D using Tapatalk
yun dishwashing sponge ng 3M bro, bali yung soft part ginagamit ko nung una. tapos ayaw matanggal ng watermarks, ginamit ko rubbing compound, nun una accident lang pag gamit ko nung part na green (matigas), since parang wala nangyayari eh tinuloy ko lang. ayun pag banlaw ng windshield, kita na fine scratches hehehe
Ace Hardware. I don't know if all of their branch have stocks for that item.
Sent from my Up Snap using Tapatalk
I would like to try using it on my windshields. I got a lot of scratches on window, and windshield aside from water marks. When my tent pole was blown down by typhoon Glenda years ago. Lumapat at kumayas yun poste na tubo ng car tent ko sa windshield front at back at window sides. Luckily, di lang nagka crack at nabasag.
DA? ibig sabihin Dual Action? Kapag Dual Action ba, may reverse rotation ba sya?
Sent from my 5015E using Tapatalk
Eto bro:
What is a dual action polisher?
Dual Action polishers are characterized by the motion of the head. It spins on a central spindle, and this spindle rotates around an eccentric offset. A good metaphor for a dual action polisher is the earth's orbit. The earth itself spins and it also orbits around the sun. Dual action polishers are also called orbital polishers for this reason.
Dual Action Orbital Polisher Guide: how to remove swirls, scratches, & oxidation with an orbital buffer. Porter Cable 7424, foam pads, backing plate,
Hello mga masters, any tips for maintaining a white car?
PAJ 4M40 MORE POWER!
Same din kay Cathy method ko, plus additional 1 step. soak in joy dishwashing, then dump all of them sa washing machine till rinse cycle lang (hehehe, medyo tamad, madami ako nagagmit for cleaning a Subcompact, a compact and an SUV), tapos rub ko perla white, babad, rinse, tapos air dry na.
The microfiber towels and applicator pads/sponges I used for polish and wax, those are the only ones I soak in dishwashing liquid. After rinsing them off they go into the washing machine with the other microfibers, this time with liquid detergent. (We usually use Breeze at home.) Spin dry, then air out to dry completely.
Dishwashing liquid to strip them of the oils and whatever residue, then liquid detergent to clean the rest. Wag lang daw powder because of tiny particles that might stick to the fibers and might scratch your car's paint.
