Page 155 of 203 FirstFirst ... 55105145151152153154155156157158159165 ... LastLast
Results 3,081 to 3,100 of 7833
    Jun 2016
    Quote Originally Posted by jvamar07 View Post
    Ok got your point. You can purchase probably a lance similar to the pressure washer you have right now. Regarding the free soap gun lance attachement. I have read somewhere you can make it foamy by putting 80%soap and 20% warm water, shake it to produce bubbles before using it. I have not tried it yet but I will soon.
    Thanks sir, might try it first before getting a foam lance. Pero mukhang mauubos agad car shampoo ko pag 80% soap 20% water. [emoji23][emoji23][emoji23]
    Jun 2009
    mga sir, tanong ko lang kung okay ba yung nanon ceramic coating?
    no maintenance daw siya and 3 years guaranteed daw ang itatagal. may nakapag try na po ba nito?
    Mar 2015
    mga master, tanong ko lang po how do you clean your engine bay?
    halos lahat ng nasa youtube eh may part na pressure-washed mismo yung engine bay after spraying with engine degreaser.
    at the same time lahat nung comments eh against that process.
    i think hindi naman talaga dapat binabasa due to the electrical components involved.
    although i am clueless aling mga parts yung bawal talaga mabasa.
    Aug 2009
    Quote Originally Posted by sylphunter View Post
    Damp cloth, mano manong punas.
    Jun 2016
    Like this one po? Kakawax ko lang kac 2 days ago. Tapos pag ginamit ko ba to, matatangal amg wax?
    Feb 2017
    Quote Originally Posted by dovahkiin View Post
    Don't know about this one.
    why would a detailer remove wax? hindi naman wax cleaner yan...
    Jun 2016
    Sir newbie lang that's why im asking. It may sound silly to you, saken concern ko lang kac ang hirap mag wax tapos baka pag ginamit ko to pang maintain. Matatanggal lang ang wax. 🤦*♂️
    you can read meguiars detailing guide. you will find where quick detailers are in the chain. there are so many guides out there. autoglym guide. mothers' also has a guide.
    Jun 2016
    ^ sir thank you sa advice. next question ko po. Pano kaya to tanggalin? done doing the clay bar step + QD pero hirap pa rin matanggal e
    it appears that it already went thru the clear coat.
    re-paint na siguro...?
    errr... what caused, it, po?
    Jun 2016
    I am not sure sir. Pero tingin ko hindi naman kelangan ang repaint. I should do sir monty told me first before thinking of a repaint. Thanks sa advice though. [emoji4]
    Apr 2012
    ^ sir thank you sa advice. next question ko po. Pano kaya to tanggalin?... done doing the clay bar step + QD pero hirap pa rin matanggal e
    looked like ashpalt tar to me, dumaan ka ba sa bagong aspalto na kalsada? di talaga kaya ng claying yan lalo na kung dry at tumigas na.
    try mo wd40, spray mo sa isang spot muna, let it linger for a while then wipe it with microfiber cloth with wd40 din. if lumambot at kaya matanggal, continue the same process, if kaya ng kuko mo to scrape it, pagtyagaan mo. kung di kaya ng wd40, subukan mo kerosene. gamit ka ng spray bottle, then same process. try mo sa isang spot muna, let it soak then wipe.
    then after, wash your car thoroughly para maalis ang wd40 o kerosene...HTH
    Nov 2014
    If this is asphalt, +1 sa kerosene. The guys at my suki carwash used this--they said they were seeing a lot of these marks on their customers since the main road nearby had just undergone roadwork. Just wax your car after since kerosene will remove the previous layer of wax or sealant.
    Jul 2015
    Aspalto.
    Kerosene will do.
    Sir Monty, bat di ka mag tayo ng detailing/ car wash shop saten? Endorse kita sa jazz club solid north group[emoji4] marame-rame din yun.
    Apr 2012
    Quote Originally Posted by makyong View Post
    Aspalto.
    Kerosene will do.
    enthusiasts lang ako bro lols! i'm planning nga to have glass coating na rin gaya sayo para less maintenance.
    Jun 2016
    Thank you so much sir monty, sir kai s and sir makyong. I will try it with koresene this weekend. I will post the result. Thanks again [emoji4]
    Jun 2016
    And oh, yes sir monty dumaan ako sa bagong aspalto. Dami kasing road renovations dto sa province e (ilocos region)
    most will scratch if the car isnt washed.
"Tamang OC lang" - a newbie's guide to car appearance maintenance
