Page 15 of 203 FirstFirst ... 51112131415161718192565115 ... LastLast
Results 281 to 300 of 7833
    Apr 2008
    Quote Originally Posted by vefyjeph View Post
    Napabayaan ko yung car ko after a heavy rain sa underground parking for 4 days ata. Ayun, watermarks galore sa roof. Di naman gaano sa hood and sa may trunk...
    I bought sa na mention na least aggressive - Meguires deep crystal paint cleaner (wala kasi ako makitaan ng KAIO) to remove those watermarks. Di kasi kaya ng wash or even Nanogloss/sliq na alisin yung marks.
    Upon applying, di pa rin naalis yung watermarks. Naghanap ako sa youtube kung pano and mukhang too little ang ginamit ko sa application... Parang nag-aapply lang ng wax yung ginawa ko na dami nung product. Yung sa youtube, ang dami nila maglagay.
    Retry ko next month o dapat try ko na lang ulit agad?
    Sir, I also have a Meguiar's Deep Crystal Paint Cleaner (step 1) and yes, even after I applied it, there were still stubborn water marks that didn't get removed though I managed to remove some. They said it's better to use with a machine but for me, I applied it manually. I did at test spot first. I put a reasonable amount on the applicator then applied a medium pressure then light pressure. After that I inspected. If there are still marks, I will put cleaner again on the applicator pad then repeat the step. That together with step 2 are the hardest to do on the 3 step process.hehe Truly shoulder killers.hehe
    If you have applied Deep Crystal Polish (step 2) and put LSP, better to just wait after 2 months or until the wax that you have applied dies. Just maintain it with a QD or regular shampoo for the time being. So that when you clean your paint again, you can do it totally from the start meaning claying, steps 1-3, etc. Besides, with the erratic weather that we have wherein it will rain then suddenly becomes sunny, in a week for sure your car will have hundreds of water marks again.
    Jan 2011
    Quote Originally Posted by alvinladen View Post
    may nabibili bang portable buffing tool? yung wireless?
    Baka cordless sir haha! :D
    oo yung nga, hehe
    was able to buy Nanosil sa ace. Question:
    1. Nanosil is like Step 1 or 2 of Mothers/Megs? PArang cleaner ba sya or sealer/glaze that hides swirls/scratches?
    2. Twing kelan gagamiting ang nanosil? Weekly after every wash ba and then Nanoglos?
    3. So recommended na dapat gamitin nanosil with machine to break the crystals?
    4. As to the application by machine, ok lang ba na mag overlap yung pag apply by machine?
    5. Kasing nipis lang ba dapat ng nanoglos ang pag apply?
    Thanks.
    Jun 2012
    Quote Originally Posted by yourman_2nd View Post
    Thanks.
    same question here may additional lang
    how lang ang curing time ng nanosil?
    if walang machine okay lang wipe off na lng with use of microfiber towel?
    Apr 2008
    Quote Originally Posted by m05tw4nt3d View Post
    Sir, as far as I know, Nanosil doesn't have a curing time. You can apply Nanoglos right after applying Nanosil. But Nanoglos has a curing time which I believe 6 to 8 hrs. So if you wanna put another layer of Nanoglos, you have to let it cure first. In my practice, I also wait for the curing time to end before I apply the Nanosliq or any other wax.
    Yes sir, I apply it by hand only and MF is what I use it applying it.
    Apr 2008
    Thanks.
    Sir, I will try to answer your question based on what I know and my experience.
    1) I wouldn't really compare Nanosil to Step 1 of either Mothers or Meguiar's. As I know, step 1 is the cleaning step such as removing any wax that was applied on the paint, minor imperfections and possibly some swirls and scratches. For Nanosil, I would say it's more a filler or sealer that would hide the swirls and scratches. Though it has some cleaning capability, I couldn't really say up to what degree it could clean.
    2) I would say the moment you see those swirls and scratches resurfacing, I believe that's the time I would reapply Nanosil.
    3) That's what the professionals said that to really unleash the full potential of the Nanosil, it's better if it's applied by machine since the pressure is equal throughout unlike if it's done manually. You can also do it by hand but you have to give an elbow grease to break down the crystals.
    4) I can't comment on this since I haven't tried applying it with a machine.
    5) I apply Nanosil as compared to Nanogloss. The way I apply it is put about an inch size on a microfiber towel then wipe on the paint. I just make sure that I put enough to cover the whole panel. Then I will start to just rub it until I don't see the product anymore. Whereas the Nanogloss, I will put a reasonable amount on the applicator pad, apply on the paint, do the finger test then buff.
    Quote Originally Posted by rna800 View Post
    thank you Sir for your prompt reply. btw, i want to share lang: yesterday i used nanosliq on two cars (both were shampooed and waxed using express spray wax a week ago), after a week's use with light rains. used nanosliq for a waterless car wash. i was happy with the result. sprayed the nanosliq at each panel (starting with the hood, then roof, then trunk and then quarter panels) and let it work for a few minutes before i used the microfiber to remove the dumi on each panel. repeated this on all panels turning the microfiber each panel para malinis lagi on the start). then buff the whole car with another clean microfiber.
    actually i think the shine and the dulas are better than just water and car shampoo. the swirl marks were somewhat fileld and hidden a bit. the nanosliq exceeded my expectations. tipid pa ako sa water and shampoo and less than half the time doing the washing, drying and waxing. the cost of the water i will save (mahal na ng singil ng maynilad ngayon ha!) will more than cover the cost of the nanosliq. even the cost of carwash (90-100) a week will cover the nanosliq expenses. one bottle of nanosliq will last up to 2 months of weekly washing.
    now i need to find where i can buy nanosliq by the litter or gallon to refill my sprayer. sa mga autoshow lang ata available eto.
    Jan 2011
    I had finished my Meguiar's Endurance Tire Gel about a month ago and probably that will be my last time buying that. Thank God I had the small bottle and not the big one. Its consistency is like silicone and they said that it could make the rubber brittle that might lead to cracking or possibly explode.
    After reading some reviews about it, I got really worried though I read mixed reviews wherein some had good experiences while some had bad. My observation was it could really make your tire really black, sort of shiny black and it lasts longer than Microtex. Downsides, I noticed, just like the reviews that I read, it made the tires brown since it's kinda sticky and dirt sticks on it fast. Plus I noticed some cracking on the tire though I don't know if it caused it. Maybe I just got paranoid since it's even written on the bottle to not apply the product on the tire thread.
    With Microtex Tire Black, I love how it leaves a matte black look (I only apply once) and not to shiny just clean look. 2nd is it's not sticky so I suppose it's safer to use and lastly, it is way cheaper than Meguiar's Endurance Tire Gel.
    Kahit anong brand pa yan,hindi talaga nilalagyan yung thread hehe!:D
    Oct 2011
    hehe, im more concern of those small rocks embedded sa thread. yes, you online apply tire gel at sidewall of the tyre.
    Oct 2011
    How do you take care of your Chamois? I bought an AutoGuard Chamois (Green - Lint Free) and after just about 2 months of usnig it, I noticed na may part na napupunit na. What is the proper way of cleaning and storing your Chamois? or hindi talaga durable itong AutoGuard Chamois?
    May 2012
    sir magandang araw, hingi lang ako ng advice,
    ano ba ang difference ng microtex nanoglos vs nanosil? which is better? same purpose lang ba sila?
    ang plan ko po kse after washing e use either the 2 of these, tpos collinite and then nanosliq na.
    ok po ba scheme ko?
    interested din ako sa claying pero i have no idea about it, even the products to use...
    thank you sirs, these thread is very much appreciated...
    Apr 2008
    Quote Originally Posted by abemanpogi View Post
    ok po ba scheme ko?
    Sir, your queries have been tackled a lot of times already. Please do some back reading and for sure you will find the answers to your questions.
    Jun 2007
    better pa rin pala Microtex Chamois. 3 months na yung akin ok pa rin. Though hindi na pale yellow yung kulay gaya ng dati kahit matagal ibabad sa Perla
    Oct 2011
    Quote Originally Posted by dfopiso View Post
    Yes, I also have seen the Microtex Chamois but decided to buy the AutoGard. The saleslady recommended me the original Chamois but the cost is quite high almost 3 times the price.
    Apr 2008
    Quote Originally Posted by stavros View Post
    I agree.
    The message you have entered is too short.
    Feb 2006
    Microtex tire black din gamit ko sa mga black plastic trims and rubbers ng ride ko ,di masyado glossy
    Feb 2011
    Ayus matry nga ang kero sa rubber ng bintana. Salamat.
    Jun 2007
    Quote Originally Posted by evincar View Post
    nagpa carwash and wax ako kanina
    medyo masakit sa bulsa talaga 600 din hehehe eto gamit nila
    Meguiars Mirror Glaze #66 Mirror Glaze Quick Detailer
    ok naman yung finish glossy talaga, ewan ko lang kung tatagal
    The glaze just polished your car's finish. You'll need a protective wax layer to maintain the shine. Try using a carnauba, synthetic or polymer wax.
    May 2012
    what brand can you suggest sir?
"Tamang OC lang" - a newbie's guide to car appearance maintenance
