Results 1 to 10 of 16
- 44
July 5th, 2004 03:34 PM #1mates,
i'm planning to paint the rear drum brakes of my ride. medyo napansin ko kasi na may konting kalawang.
should i be careful of any moving parts in the brake system that shouldn't be painted?
thanks.
July 5th, 2004 04:17 PM #2
Baklasin mo na lang kung brake drum para makasiguro ka na di mapipinturahan yung hindi dapat. Use high temp spray paints, para di mabakbak agad ang pintura.
Pero mas makakamura ka sa steel brush at liha, kung mababaw na kalawang lang naman ang tatanggalin.
July 5th, 2004 11:04 PM #3
good advice Ungas...DT, you will need the steel brush and light sandpaper anyway, because if you paint the brake without removing the rust and completely 'scuffing' the surface, the paint will peel and it will look even uglier than the rust itself.
- 44
October 23rd, 2010 09:11 AM #5
can anyone recommend where pwede pa paint ng drum brake? pangit tignan may kalawang. no time for DIY.
- 199
October 23rd, 2010 01:21 PM #7sa may welcome rotonda ako nagpagawa. sa N. Ramirez. tapat ng dating kuwatog. meron dun expertise nya un drum brake
- Oct 2010
- 14
December 7th, 2010 10:58 AM #8does anyone know kung meron sa south area? and magkano usually inaabot painting? usually red ang nakikita ko, pwde din ba kayang black or silver?
December 7th, 2010 11:05 AM #10
tanong nyo sa kilala ninyong pintor ng sasakyan ang price at para masmaganda ang gawa. sa masmalapit sa lugar niyo para nakikita ninyo at madaling ibalik kung meron problema.
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
