Results 1 to 16 of 16
  1. DT is offline Verified Tsikot Member
    Join Date
    mates,
    i'm planning to paint the rear drum brakes of my ride. medyo napansin ko kasi na may konting kalawang.
    should i be careful of any moving parts in the brake system that shouldn't be painted?
    thanks.
    Baklasin mo na lang kung brake drum para makasiguro ka na di mapipinturahan yung hindi dapat. Use high temp spray paints, para di mabakbak agad ang pintura.
    Pero mas makakamura ka sa steel brush at liha, kung mababaw na kalawang lang naman ang tatanggalin.
    good advice Ungas...DT, you will need the steel brush and light sandpaper anyway, because if you paint the brake without removing the rust and completely 'scuffing' the surface, the paint will peel and it will look even uglier than the rust itself.
  4. DT is offline Verified Tsikot Member
    Join Date
    ayt, thanks mates.
    Jun 2007
    can anyone recommend where pwede pa paint ng drum brake? pangit tignan may kalawang. no time for DIY.
    Dec 2008
    mas maganda kung real painter ang gagawa sa painting ng drum sir l
    sa may welcome rotonda ako nagpagawa. sa N. Ramirez. tapat ng dating kuwatog. meron dun expertise nya un drum brake
    does anyone know kung meron sa south area? and magkano usually inaabot painting? usually red ang nakikita ko, pwde din ba kayang black or silver?
    Quote Originally Posted by lloydwena View Post
    Mga magkano kaya doon sir?
    sir, ayus yan ginawa mo ha...asan mo pinagawa sir?
    500 pesos lang dun
painting the drum brake...
