Page 24 of 44 FirstFirst ... 1420212223242526272834 ... LastLast
Results 231 to 240 of 434
    Sep 2010
    #231
    Mga pressure washer ba dapat sa drum kumukuha ng tubig or pwede naka direkta sa gripo?
    pag self-priming yung pressure washer pwede humigop sa drum.
    yung nabili ko na bosch unit pwede direkta sa gripo or humigop sa balde.
    kaso maingay. di ko pa naayos yung kaha nya na me insulation kaya yung
    12v na mini pressure washer muna ginagamit ko.
    Feb 2014
    #232
    Quote Originally Posted by carwhacko View Post
    Ang mura ha. Tell us your reviews!
    mura nga. lazada. less 200 using PAYMAYAAPR code
    it works. actually more powerful than i need it to be. now the only question is durability but that all-metal pump housing looks promising... but if it breaks prematurely i guess it's ok it's cheap anyway
    Feb 2014
    #233
    Quote Originally Posted by Lew_Alcindor View Post
    This is a water pump right? Not specifically a pressure washer.
    pressure washer
    is this made in japan?
    i have strong faith in "made in japan" items.
    "taiwan" daw. but i don't see any proof. so it's safe to say it's made in china
    #234
    Quote Originally Posted by Vodka View Post
    Nakasulat ba yan sa box? Na self-priming?
    #235
    pressure washer
    and as china claims taiwan is part of their kingdom...
    Dec 2017
    #236
    If ever it is not indicated, the best way to know it is to test it. You can try to lift the pump at a considerable height then have the suction hose take water in through a pail and not through a faucet.
    I doubt a centrifugal pump will be able to have any suction effect. From what I know, a centrifugal pump is not a self priming pump.
    #237
    I don't think every stores let them test pressure washer
    Dec 2017
    #238
    Yes, I don't think they will ever let you test it. I'm referring to those who buy from Lazada. This is the reason why I seldom buy from online stores when it is available in a local market. The drawback of course, is that I pay much compared to some items at Lazada.
    #239
    There's no other way to know if it's self priming?
    Dec 2017
    #240
    If you can confirm the type of pump, then that answers your question. Again from what I know, centrifugal pump is not self priming while reciprocating pumps are self priming.
pressure washer brands
