Page 23 of 44 FirstFirst ... 1319202122232425262733 ... LastLast
Results 221 to 230 of 434
    Feb 2014
    #221
    so i paid P2244 for this fujima. hope it isn't crap
    Jan 2012
    #222
    Quote Originally Posted by Vodka View Post
    Ang mura ha. Tell us your reviews!
    Jul 2013
    #223
    This is a water pump right? Not specifically a pressure washer.
    #224
    is this made in japan?
    i have strong faith in "made in japan" items.
    #225
    Mga pressure washer ba dapat sa drum kumukuha ng tubig or pwede naka direkta sa gripo?
    #226
    if the gripo can easily supply the required flow rate, gripo is ok.
    if in doubt, sa drum reservoir.
    in our case, our gripo supply is erratic. we connect the pump to a drum reservoir (actually, a jumbo timba!) that has been previously filled up by the gripo.
    pag na-ubos ang drum reservoir, "it's coffee break time".
    #227
    Usually ilang dapat psi ng gripo? But i think our pressure is enough since umaabot naman sa overhead tank yun Maynilad.
    #228
    naku... hindi ko alam. beyond my powers yan.
    sorry.
    but the product manual may have the minimum requirement.
    butipakayo!
    our maynilad comes on, only late at night. we have a drum reservoir for it, from which our electric pump gets water to push into our pressure tank.
    Sep 2010
    #229
    I hope there is an attachment so you can plug it in a household outlet.
    i have a rechrgeable compressor with a cig lighter socket - un muna ginagamit.
    you can buy a power supply din - 220 to 12v/10A for this.
    Dec 2017
    #230
    If pressure washer, make sure your water is filtered to avoid water spots or sediments from spewing out towards your car.
pressure washer brands
