Results 31 to 40 of 41
November 13th, 2006 05:41 PM #31
makitanong na nga rin mga bossing, yung kotse ko po me dati nang undercoat, tapos nung minsan nagpachange oil ako sa gas station nung nilift na yung oto ko sinamantala ko na pagkakataon silipin yung pang ilalim, ayun! me konting portion ng undercoating na natanggal na! ang masaklap pa, kinalawang na yung flooring ng kotse! eto po tanong ko, pwede po ba pa undercoat ko ulit kotse ko at kung pwede, buong pang ilalim po ba ulit? or yung portion lang na natuklap yung undercoat? thanks in advance sa mga sasagot...
November 13th, 2006 06:00 PM #32
November 13th, 2006 06:35 PM #33
^^^ Yeah, dapat nga lihain, tapos body filler (if needed), primer then paint. Kung ako nga, I'd have the whole undercoating stripped to see if the water seeped in since nagbabakbak na kamo. Then ipapaulit ko na lang.
November 13th, 2006 06:43 PM #35
June 16th, 2010 03:43 PM #36
buhayin ang thread!
kaka-undercoat lang ng revo ko last monday. tar "alketran" ang ginamit. pero hinaluaan ng kerosene para mas madali spray or parang thinner. stayed sa garage whole day tuesday. ayun, tuesday afternoon pwede na haplusin ang wheel wells. tayu na & walang tulo. 2 gals ang nagamit. kickback na nung boy yung 1/4 gal na tira.
May 2nd, 2013 11:40 AM #37
ako din papa undercoat this weekend. hope it will turn out well. sa Petron CCC naman ako,
procedure nila is may kerosene din para matanggal yung nasobrahang spray then car wash then yung engine lilinisin na din daw.
May 4th, 2013 02:28 PM #38
tapos na ako kanina. maayos yung gawa.
ung lumampas ginamitan nila ng diesel or kerosene ata pang alis.
- Jan 2008
- 4,726
May 4th, 2013 06:41 PM #40with today's technology, i don't see the need for an additional undercoating... it will just invite dirt...
what you should check in your car are the body drain plugs.. the car's body will corrode if water stays in it combined with soil that makes water to stay longer...
Xiaomi E-Car
