Results 611 to 620 of 635
January 23rd, 2020 10:25 PM #611
- 52,731
January 23rd, 2020 10:35 PM #612
- Sep 2016
- 2,278
January 24th, 2020 09:37 AM #613Kung simple dent lang yan, baka mas mura at mas mabilis pa pagawa sa PDR kesa ipasok mo sa insurance. Pero icheck mo pa rin po.
- Apr 2006
- 57
January 26th, 2020 12:03 PM #614Thanks sa mga suggestions..pero policy 3.5k ang participation. nag tanong na kasi ako sa pdr bubutasan daw yung part na gagawin so hindi din advisable.
- Feb 2020
- 1
February 20th, 2020 11:58 AM #615How much usually yung pagawa kapag minor dent? May nadampian kasi akong car tapos 3k yung hinihingi. Reasonable ba yun with this kind of dent?
- 52,731
February 20th, 2020 07:57 PM #616
January 19th, 2021 08:24 AM #617
Parking entrance barrier fell on the double-walled roof frame of the Camry (didn’t blame the attendant as it would probably cost him his job).
Anyway, my trusted PDR tech took a look at it and he said (though didn’t recommend it since it would compromise structural integrity and might cause rust issues) it would entail cutting a hole behind the frame as it’s double walled to do a proper repair using his method.
He did mention though that a professional “glue pull” method, which he currently doesn’t have, might do the trick. Anyone know of a shop using this method? Preferably south, but anywhere in the metro would be fine.
Cheers!
- 52,731
January 19th, 2021 08:29 AM #618many years ago,
when my car's roof caved in, for reasons we could not fathom,
we simply pushed the metal outward from inside the passenger cabin.
we didn't even have to remove the ceiling cover.
i know of some workers who would drill a small hole thru one of the metal walls, in order to manipulate and fix the double-walled segment.
i had one such repair on our running board.
after several years, the area still looked fine on the outside.Last edited by dr. d; January 19th, 2021 at 10:14 AM.
January 19th, 2021 09:47 AM #619
January 19th, 2021 01:39 PM #620
A rock landed on my trunk lid right behind the area with a double wall. Had it fixed at Ortigas Autohub. The PDR tech recommended the same thing. He filled and repainted the hole after the repairs were done. I check it every now and then and noticed no rust streaks. That was more than a year ago.
Saken sir Minsan NASA 2k stable mga 2to3 minutes mag up and down need pa re start para maging...
high idle RPM at engine start
